Question about Sony VPL-EX3 LCD Projector
I have a sony VLP-EX3 with some ghosting issues. I am able to get into the service menu and change the SHSHI sentings and fix the problem. How to you save the changes. Everytime I power of the projector the changes are lost.
AJIN G
  • 6694 Answers
SOURCE: my sony projector vlp-cs4 is
hi,
check the power cable first. also check the power at the wall out let. if all ok, the ur projectors smps power supply have some problem. check the same if found faulty replace it. for any assistance feel free to contact through fixya.
ok
Posted on Dec 26, 2010
caroldon
  • 17130 Answers
SOURCE: Sony VPL-EX3 projector on/off switch
Possible that the lamp is faulty -if the hours have elapsed- check the lamp holder, the fitments.
check also the filters, clean and reset.
Make sure the power supply Unit is not having any poor soldering or faulty components to reduce the voltage output to the lamp thus making it shut down..
Posted on Jan 17, 2011
AJIN G
  • 6694 Answers
SOURCE: I have replaced the lamp
DO the following for resetting the lamp hour
1.Connect the power cord.
2.Press the following keys on the Remote Commander in the following order for less than five seconds each: RESET, Left Arrow button, Right Arrow button , ENTER.
ok
Posted on Feb 09, 2011
  • 59 Answers
SOURCE: have replaced the lamp in
Press the following keys on the remote control in the following order for less than five seconds each:
Posted on Feb 21, 2011
SOURCE: How do you turn the
Pressing the On/Off Key for 10 seconds switches on and off the projector.
While on, press the menu key for 10 secods to reset it to unlock.
Posted on Mar 14, 2011
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
How do you turn the panel lock off on a sony vpl-ex3 lcd projector?
Jan 12, 2011 | Sony VPL-EX3 LCD Projector
Sony 60
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unuseable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Nov 03, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red ghosting
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unusable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Oct 31, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red shadow on screen double image
Well this is the fix for the usual Ghosting problem....
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone
Jul 19, 2008 | Televison & Video
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
50" rear projection sony HDtv and ghosting when using my ps3
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony VPL-EX3 LCD Projector Logo
77 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
