Question about Dryers
Kenmore Dryer 11076822695 does not heat up. Everything else works.
    Problem Solver:
  • 14 Answers
You have a heating problem so go to the link and you can download a video to see how to test and determine which heating thermostat or component has failed and needs to be replaced.
Dryer Repair
Posted on Mar 19, 2011
Kenmore model 110.63942101 (electric). everything works but no heat... drum spins, timer works. Should I buy heating element replacement kit? does it need to be installed from the back of the dryer...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Kenmore Dryers
Kenmore dryer @11064982300 runs but no heat..did all the steps to troubleshoot & everything seems to be working...can't figure out why there is no heat
heatman101
Jul 08, 2011 | Kenmore Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
The dryer will not heat, everything else works.
If this dryer is electric and everything are working the most probable cause should be the high temp thermostat located within the heating elements and also the overtemp sensor located close to dryer exhaust vent. If this is a gas dryer check the electric igniter located within the burner area.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
