Question about Janome Memory Craft 9000 Computerized Sewing Machine
My Janome 9000 has no power. The fuse in the plug is ok. Are there any other fuses in the machine to check or could it be the transformer? If this is the case would it be worth having it repaired?
4 Suggested Answers
SOURCE: janome 9000
On the bottom of the machine is the base plate, remove it. You will see a black box (the transformer) that needs to be dismantled. Once inside you will see 2 fuses, one will be blown.
Replace the blown fuse, do not remove both fuses at the same time and get them confused.I bought replacements at Radio Shack. Good Luck
Posted on Feb 03, 2008
RickE1
  • 202 Answers
SOURCE: Janome/New Home Memory Craft 8000
Most likely you will have to remove the covers and find the fuse on the circuit board. But be carefull as any static from you may harm the circuit board. Just touch something that is grounded first and release whatever charge you may be walking around on, carpet, etc. Removing the covers is no big deal. Just remember where the screws came from and put it back togeather in reverse of how you took it apart. You can have the dealership order a fuse for you. Might save you 50.00 or so. Good luck.
Posted on Oct 02, 2007
Zenqi
  • 208 Answers
SOURCE: WHERE IS THE FUSE FOR THE JANOME MEMORY CRAFT
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
Posted on Jul 11, 2009
Why does my janome 9000 have no power? I cant find any thing wrong. Is it worth fixing?
Have you checked the foot switch? Is there a transformer in the line?
Is the plug making contact, in both the wall and at the side of the machine? Is the foot pedal getting hot when plugged in? You will need a voltimeter/ohmeter to check this out.
Dec 11, 2014 | Janome Sewing Machines
I was embroidering on my janome 9000 it jammed and went dead and won't come back on!
Be sure that it's still plugged in and not on a plug in that is controlled by a switch that got accidentally turned off.
Other than that it is likely that a fuse got blown or the power supply died. In that case take it in for repair.
Dec 12, 2012 | Janome Memory Craft 9000 Computerized...
Janome 9000 wont come on
it could be the motor, or it could be a fuse, or the power cord,, I suggest taking the machine in for a check up to find out what's wrong
May 20, 2012 | Janome Memory Craft 9000 Computerized...
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
Janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Mar 05, 2010 | Janome Memory Craft 9000 Computerized...
I have no power going to the machine. It's as if there is a blown fuse or something inside the machine. Does the Janome 9000 have a fuse inside the machine? If so where.
NO FIRST CHECK THE PLUG SWITCH HAS NOT BLOWN , ALSO CHECK FOR ANY BREAKS IN WIRE . IF ALL OK IT MAY BE THE CARBON BRUSHES HAVE WORN DOWN.
Nov 01, 2009 | Janome Memory Craft 9000 Computerized...
Janome 9000
The first thing to be checked is the fuse in the bottom of the machine. Have a different dealer do this check. If the screen lights up it is not a burned out fuse. Find an Authorized Janome dealer that you trust and let him check this machine.He is the only one who can get circuit boards from Janome. The machine does have built in diagnostics for some problems.
sewman7
Aug 25, 2008 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
46 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
