I have a Panasonic PT56LCX16.....Just replaced bulb , played one day & now it's giving me a 7 code (led) . Has no pic no sound . The fan will run about 2 minutes when plugged up then it turns off .Could you help me with this . Could you give me the list of trouble codes for this set. Thanks JM45
  • jffryjrdn Mar 18, 2011
    Thanks for your help .... I really appreciate it. JM45
    Thanks for the information.... Jm45
  • 19,396 Answers
Hi.
7 Blinks is Abnormal Voltage (+17V, +9V, +5V line) for LCD Drive C.B.A.
Check that the bulb is correctly installed. The fault is fixed testing PSU and then testing the LCD drive CBA in picture below:
Posted on Mar 18, 2011
  • Ginko
    Ginko Mar 18, 2011
    Hi.
    I wanted to add that the most frequent fault is not the Drive CDA.
    Problem can be a contact or the power CDA. The PSU is the most common problem triggering 7 blinks. +17V, +9V, +5V DC from PSU must be tested. The +17V, +9V lines must be jumped if the TV is in error mode, +5V is on. The base board must also be tested. If the rest is OK, then the tech check the LCD drive.
    All the best.
    Ginko.
I need the instruction for how to reset a timing on a pt56lcx16 when you replace the lamp
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 31, 2014 | Panasonic PT56LCX16 TV Lamp
My Panasonic PT-60LCX64 television keeps having a problem with temperature. Every few hours, the TV will turn off and the temp light will blink 4 times. It will turn back on if we give it a rest of 10
Sounds like a fan issue which is possiblt slowing down as it gets warm. I would try removing the rear cover and set a fan behind it blowing on the chassis and see if the set keeps running if so the fans would be suspect.
Oct 14, 2012 | Panasonic PT-60LCX64 Television
When I press the remote control of the Panasonic Ceiling Fan F-MY143 the fan has no respond at all. The remote control work well with others fan. The fan can't turn smoothly. Help needed.
Hi all,my Panasonic Ceiling Fan F-MY143 speed can't be control using remote controller. When remote controller is being pressed, led blinking and a beep sound can be heard. Pls help, thanks in advance.
Mar 02, 2011 | Panasonic Dryers
Just replaced bulb. Solid yellow led with no pic
hello make sure the lamp is fitted securely and the lamp cover is fitted securely aswell good luck
regards
shaun
May 21, 2010 | Toshiba 62HM196 62" SD Television
Toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Aug 09, 2009 | Toshiba 52HM95 52" HDTV Projection...
Bad Bulb?
the pins that protrude into the lamp compartment have a tendency to get out of alignment where the lamp will only make partial contact. It sounds like what youre describing.
Jun 15, 2009 | Televison & Video
Changed bulb and still no picture or sound
hello i think when you put a new bulb in you have reset the bulb counter good luck
shaun
May 30, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
