Question about Refrigerators
I HAVE A KELVINATOR FRIDGE MODEL KNT 28BGEW (BOUGHT JULY 2008) HOW MUCH WOULD A FUSE AND A TIMER ( A SIMPLE DEVICE WITH A FEW PLASTIC GEARS AND AN ELECTRIC COIL WHICH REGULATES THE AUTO DEFROSTING OF THE FRIDGE) COST? THE FUSE IS A SIMPLE GLASS-TUBE TYPE THANKS
  • 87 Answers
SOURCE: Water dripping from top of fridge (coil housing?) under freezer.
It could well just need defrosting. It does sound as though the coil in the freezer section is frozen. If you try defrosting it and the problem disappears then you have at least found a temporary solution. If it does rectify it I would closely monitor the cabinet for a couple of weeks to check for a reoccurrence. If it does reoccur then I would suggest contacting a fridge guy so that he can check the defrost circuit. The reason we normally suggest to defrost is incase a door was left ajar and the coil froze up because of this. I hope this is of some help and you seem to be on the right track.
Posted on Sep 11, 2007
  • 1073 Answers
SOURCE: Problem auto defrost refrigerator
loaded question any COULD be bad a volt ohm meter will tell you whitch one is bad
if this is a ge sxs i would check the defrost heater first
Posted on Jun 24, 2008
huuum
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
I have a kelvinator impression series 300 and bought it second hand. The fridge component is freezing all our food and there is icicles on the back wall of the fridge. I have tried changing the thermostat...
I have the same fridge.only a week a go my wife bumped the temp control in the freezer. It ended up freezing up so much. The fan that blows the cold air down to the fridge, couldn't . If you take everything out of the freezer. There are little plastic round caps covering the screws in the back panel. Remove the caps ta
Jan 27, 2014 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Kelvinator c302f-r fridge is freezing everthing
sounds like thermostat if its non frost free model,otherwise it is temp sensor.need model number to clarify.
Apr 25, 2012 | Kelvinator Refrigerators
We bought a kelvinator ref KTD300MN. I would like to ask if the freezer inner rear wall should form some ice? thanks.
No.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Mar 26, 2011 | Kelvinator Refrigerators
Kelvinator refrigerator model c520h-r icing up in fridge section
if it is frost free type refrigerator try to check defrost heater defrost timer or the thermo disc if good by using ommetter.
Jan 23, 2011 | Refrigerators
I bought a Kelvinator fridge in July which seems to run constantly, it has now been relegated to the garage, whats the problem? It is model No KTM 4200WB
Most refrigerators have about a 70% duty cycle, depending on ambient room temperature, content, etc. If your unit is indeed running all the time as you state, it may be low on refrigerant, have an inefficient compressor, or an air flow issue. Make sure there is no frost buildup in the freezer, the fans are running, door seals are good. If all above looks good and the temps are ok, you may just be catching it on a cycle on time and not noticing it cycling on and off, especially it being in the garage. If the temps are questionable, my money is on low refrigerant level.
Dec 29, 2010 | Refrigerators
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
Kelvinator F/Freezer not working. Not fuse
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Feb 12, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Hello redwood City
Welcome
You said,
copper tubing."
Whirlpool remedy
Thank You ,
HUUUM!!
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
