Question about Epson Stylus NX400 InkJet Printer
I am trying to print on vellum paper and my printer will not recognize it. I tried opening up the control panel on my computer and vellum/lightweight/film/transparent are all not options for paper types. Is there anything I can do?
  • Epson Master
  • 4,336 Answers
The printer has no ability to know the paper type, this setting happens in SOFTWARE, like Word. Then the command is sent to the printer, more commonly you would change papertype for photo printing....Look in the software, and not the printer itself.
Posted on Mar 18, 2011
HP Desk Jet F4280 Printer
In Windows go to the control panel and click Printers. If possible open the print spooler and check to see if Windows is "stuck" on the print job that was in progress when the printer jammed.
Sometimes Windows doesn't "let go" of the pending print job and it will prevent further printing if it didn't get the message that the jam has been cleared. You can also try disconnecting the printer, open and close the print door and also remove and reattach the rear panel (if your printer has one). Then reconnect the printer and see if Windows properly recognizes that it is ready to print.
Feb 26, 2015 | Hewlett Packard - Desk Jets HP Officejet...
Why won't my minolta 2300DL print on any kind of vellum? So strange.
well..some printers can't grab that slick of a paper medium..let me show you an old trick we used to use
May 27, 2008 | Konica Minolta magicolor 2300DL Laser...
Tracing paper not picking
If you mean Vellum paper, make sure that your paper type is set from your server/computer to the printer. Remember, Stock rolled paper has different physical characteristics than Vellum. Also this will aid on the paper sensor to note what type of paper you are printing on
Jun 02, 2014 | HP DesignJet 430 InkJet Printer
I cant print on white vellum paper on my epson stylus nx420 i need to print some invitations and it is just folding my paper
Try placing some standard paper behind the vellum paper, it might assist in holding correctly while printing.
Being so thin the paper I would guess is folding up under the print head? if so look through all the printer properties, under the maintenance section there may be a "set Plattern Gap" (set to wide) or "Thick Paper Setting"
Selecting these raises the print head up to allow for thicker paper to pass through, but can also help thinner paper from folding up under the heads.
I hope one of these works for you.
Regards GM
Apr 12, 2011 | Epson Stylus NX400 InkJet Printer
Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Oct 17, 2009 | HP Color LaserJet 2600n Printer
Why won't my printer print on vellum paper? Im trying to make baby shower invites and the paper just comes right out.
Im guessing ...
I had a similar experience with a different brand ...
Your printer thinks it grabbed two sheets of paper.
Open your priter program (in the control panel) and see if there is a setting for Vellum
I hope this works for you
a
Oct 13, 2009 | Epson Stylus NX400 InkJet Printer
I can't get my Epson Nx400 all in one to print on vellum. It just spits the paper through...Help!
I had this same issue and I got the printer to print on vellum but I can't say it looked all that great. But here's what I did. I went into the printing preferences and then to the maintenance tab. On the maintenance tab you'll see an option for Printer and option information. Click on that and then you will see a little check box down at the bottom of the pop up and it says Thick paper and envelopes. Put a check in the box. Click ok and then it should print on the vellum for you. Make sure you put the vellum in the printer the right side up (front side) because if you don't it will print all messed up.
Jun 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Kodak printer will not print on vellum paper
THIS IS TRUE OF ANY TYPE OF PAPER, MOST MANUFACTURE RECOMMAND THERE OWN BRAND OF PAPER FOR SPECAIL USES OF THERE MACHINE AND IF YOU USE A GENERIC TYPE OF PAPER YOU WILL HAVE THIS PROBLEM, PAPER WILL NOT PICKUP, PAPER MAY JAM ALOT, PAPER PRINT QUILITY MAYBE BE POOR, INK MAY MEER, TOMERS ARE SOME OF THE PROBLEM TO ALONG WITH PAPER ISSUES ALSO, YOU MAY HAVE TO USE A THICKER OR THINNER VELLLUM PAPER, CALL A REPOGRAPHIC STORE , ONE DO BLUE PRINT PRINTING, MAP COPIERS, ASK AND SEE IF THEY HAVE ANY OTHER IDEAS
ROD THE CANDYMANGANDY
Feb 02, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Epson Stylus NX400 InkJet Printer Logo
394 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
