Question about Garden
How to tell if your battery is charging - Garden
  • 4,336 Answers
You use a volt meter to test charging, but I am not aware of chain saws with charging systems....BUT a 12 volt battery should have 12.5 to 12.6 sitting while off, and 13.8 to 14.5 when charging...
Posted on Mar 18, 2011
If you can please tell me how I can tell when I need to charge the battery. I also need to know the amount of time to that I should continue to charge it. Can over charging hurt the battery???
The Tablet should have a Icon, showing you Battery Life , (ie) how much you have left in battery . You can't over charge battery , as computer has safty cut off,
Mar 15, 2015 | Tablets & eReaders
Batery wont charge when u jump,, new battery 5 months ago
You need to go to auto parts store and have them check that the alternator is charging the battery. They do this for free. Also have them check the battery to make sure that there is not a bad cell in the battery. This can happen from time to time. if all of that is good u may have a drain on the battery. Check that all lights go out when u shot down the car.
Apr 27, 2014 | 1997 Mitsubishi Montero
How do you know when the battery needs charged or is charging
there are a couple of ways to check, if your battery has a test light indicator you can press it will tell you about how much power is by how many lights light up, if it doesn't have one, you may have to trust the windows power indicator. if you go to control panel you can go to your power options and one of the tabs should have a power reading. Also some bios versions have a battery section which tells you how much battery life there is. until they make a charger that automatically shuts off when the battery is charged this is the only way to tell
Jan 31, 2012 | iGo Green Laptop Wall Charger PS00132-2011...
Battery light comes on and off, changed battery cleaned all connections light still comes on and off
Battery light is a signal from the alternator that charge is below a given voltage , check charging system.
Oct 24, 2009 | 2000 Ford Focus
Battery fully charged but still shutting down when disconnected from mains
Find another battery it says like the one you have is faulty. If you try another known good battery and that fails just like yours then try a know good ac adaptor. If that fails, then its a problem with the motherboard not charging batteries properly but it really does sound like a faulty battery from my experience.
May 08, 2009 | Acer Aspire One PC Notebook
The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Mar 15, 2009 | Toshiba Portege R100 Notebook
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
New battery not charging
It is normal for a battery to degrade after a year since its a consumable part. It's just like any ordinary rechargeable battery. We have 2 points of failure that might be causing the problem. First the battery itself. Second the Charge board that charges and detects the battery. Given that the NON-DELL battery is working on other dell Computer, it simply tells us that it is the charge board that needs to be replaced wich is integrated to the motherboard. If your warranty is still active, call dell and tell them that you've tried a Known good battery and its still not charging. However, you might also consider that dell computers are designed for dell batteries. the charge board might have problems charging the third party battery since its not configured to do so.
hope this helps.
Demmy
Dec 10, 2007 | Dell Inspiron 6400 Notebook
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
