Question about Ricoh Aficio 2022 Black and White Copier
Sc 542 being displayed - Ricoh Aficio 2022 Black and White Copier
  • 263 Answers
There is several post here that you could see. But i will post again the solution.
You have a bad reading of the temperature of the fuser unit.
You need to reset the code.
For that try this:
Press yellow key
On the key pad press 1-0-7
Old down the red key at least 3 sec.
Enter the service mode. For that on the touch screen press "copy SP".
Exit all the way out.
Turn the machine off/on.
If you already did that and doesn't work probably you have a thermistor or a thermostat broken.
If you do not have technical training i advise you to call your provider.
Hope that help.
If you have any question reply to me.
See you
Posted on Mar 18, 2011
4 Suggested Answers
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
20YrsCompExp
  • 227 Answers
SOURCE: sc 542-00 trouble code
SC542 is a fuser error code and can ONLY BE RESET by a tech. Type pressing clr mode (button) then 107 then press and hold CLR Stop until a menu pops up. turn offf main power then on again. If there is no serious problem the code will not come back. IF it does call a trained tech. DO NOT CHANGE ANY SETTING in the menu that comes up after pressing in the code. YOU COULD RENDER YOUR COPIER INOPERABLE!!!!!!
Posted on Mar 27, 2009
M2Tech1
  • 313 Answers
SOURCE: Display is showing code SC 542.
the error is for a heating eror in the fuser either toner build up on the thermistor or the thermofuse has blown if you have the machine turned on press the yellow clear button and then input 107 and then hold dowwn the stop button.. turn machine off and wait a few seconds then turn back on.. this should clear it if it was just a fluctuaction in temps.. if that doesnt work take fuser out and check the condition of the temp sensors and do reset again.. if the code stays on you will have to go into the service mode.. acccessed the same way as reset but you need to enter the copier sp and then go to 5.Mode and look for 810 this is the sc reset execute turn off and then on >>>>Hope this helps A
Posted on Jul 30, 2009
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
How do i reset SC542 error in Ricoh Aficio SP300DN?
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Feb 23, 2015 | Ricoh Office Equipment & Supplies
Error sc 542
this is a fusing error
change the set of thermisters in the fusing unit
Jan 20, 2014 | Ricoh Aficio CL3500N Laser Printer
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
Ricoh sf3410 sc 542
go to maint. mode. Press Clear/Stop 1 0 7 . press Start key(hold) until you see maint. mode displayed. look for Fuser SC reset. reboot machine.
Oct 28, 2010 | Ricoh Aficio SP 3410SF Laser Multifunction...
Functioning problem with aficio 1033 or 2033,not sure, church cop
You must check the display for a code like SC-542 or something loke that.
Sep 17, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Sc 542 error code
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2022 Black and White Copier Logo
101 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
