Question about Vacuums
Has a Bissell, Pro Heat 2X rug shampooer. It powers up & and the motor runs but the brushes are not rotating and water is not being dispensed.
    President:
  • 1,961 Answers
Brush roller not working and water not dispensing was mostly caused by a brush belt being broken or is out of place.
Turn the machine off and unplug it if the Brush roller do not turn. Remove any objects caught in the brush roll. Also, recline the machine with the detent pedal; the brush roll will not work with the unit upright. If neither solution resolves the issue, remove and replace the small brush belt.
You better check if the small brush belt has come off to the brush end, securely refit it to its proper place. If the brush belt is broken, I do advise you to call Bissell Free Call 1800 number again and press Option 4 for spare parts and order replacement small Brush Belt
The machine is equipped with a circuit breaker that will automatically shut off the
brush if a large or loose object is caught in the brush roll.
Check also the large brush belt if its in proper place.
Let me know if you want me to help you further.
Please post here the model of your Bissell Pro Heat..
Thanks
Posted on Mar 18, 2011
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
Very little suction leaves rug wet.
Check tank and tubes for clogs. Make sure your belt and brush are working. Also make sure you are not overfilling your tank.
800-775-6586
GoodVac com
Feb 24, 2015 | Bissell 2X Proheat 9200 rug cleaner
I have a bissell pro heat and the brushes are not rotating at all,it still sprayes water,everything else is ok.
most likely the belt theres one on each side if not you'll need to take it in its the safety switch or lower motor
Dec 13, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Vacuums Logo
63 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
