Question about HP CPQ175KB Keyboard
Is there any way to type and up arrow and down arrow in a letter?
  • HP Master
  • 4,350 Answers
Yes, look for Wing Ding fonts, within your word processor.
Posted on Mar 18, 2011
Arrow not releasing upper case letters to lower case letters
Have you tried a power cycle? Power off, wait 20 sec or so, power on.
Jan 09, 2016 | Apple iPhone 5
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
I need tray 2 to be the default setting for this printer. It always reverts back to tray 1 everytime I try to print.
Paper Handling Issue -
Hit Menu
Arrow down to Paper Handling and hit the green check
hit the green arrow to go into Tray 1 size - arrow down to envlope #10 hit the green arrow to save
arrow down
hit the green arrow to go into Tray 1 type - arrow down to envlope hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 size - arrow down to letter/legal (depends on what your using) hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 type - arrow down to plain (assume that your using plain paper) hit the green arrow to save
also pull out the paper tray and confirm the guides (where you can adjust from letter to legal etc)
is set correctly.
That should take care of it unless the document you are tring to print is a different type of paper size.
Oct 19, 2010 | HP LaserJet P3005n Printer
L letter is typing upside down
This is caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Sep 02, 2010 | IBM ThinkPad R51 Notebook
Lexmark e352dn-load manual plain letter message
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputer is sending other paper size/type settings.
Aug 20, 2010 | Lexmark E352dn Laser Printer
When we send any file to print it is giving load manual feeder error
This will set up your printer for plain letter paper and should relieve the manual feed error unless your computer is sending other paper size/type settings.
Aug 09, 2010 | Lexmark X364dn All-In-One Laser Printer
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Just installed the 4200 pcl 6 drivers. On server
Press the green buttton, arrow down to Paper Handling, arrow down to tray 2 size and tray 2 type and verify they are set to "letter" and "plain".
Jun 24, 2009 | HP LaserJet 4200 Printer
Printing
Try the settings in the printer.
Push Menu button till you see menu
then the down arrow around the enter button till you seetray settings - hit enter
go the paper size - hit right arrow
hit down arrow to the MPF then hit right arrow
then down arrow to change to "letter" size
Good Luck
Aug 15, 2008 | Dell 3000cn Color Laser Printer
Printing 5x7 invitation
use the mpf tray. go to the machine press menu down arrow untll you get to tray settings. right arrow over till u get to paper type...then down arrow till you see paper size...right arrow again till u see tray 1...down arrow till you see mpf..right arrow till you see letter. Now that you are in the mfp section you can down arrow and you will see serveral selections I would keep it at letter. when you select it an * will appear next to letter. Then select menu and you and the printer is set. Now go to the print option in the program that you are using and when the dialog box to print opens select properties. go to paper quality the mpf should be selected in the tray souce. Now go down and you will see the advance button, click on that you will see Paper/Output make sure it says Paper Size and Letter is selected. Media Type should say Plain 1. If the invitations is on a heavier paper like card stock click the down arrow and select Covers 1 . If your paper is coated like matte finish photo paper select Coated 1. Now click ok. Do a test print and see if you get what you want. If not, let me know.--Deeva
May 21, 2008 | Dell 3100cn Laser Printer
HP CPQ175KB Keyboard Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
