Question about Dell Latitude D600 Notebook
Battery light flashes green once then amber 3 times dell c840
  • Dell Master
  • 998 Answers
Usually that means there's a problem with the charging of your battery. Remove the battery and see if you get the same results. If not then either your battery has to be replaced on your circuit that charges it is defective.
Posted on Mar 19, 2011
Dell c640 battery not charging
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 02, 2013 | Dell Latitude C640 Notebook
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Power light is blinking green and amber
my power light flashes green/ amber as soon as it is plugged in, with a dead battery. It seems to go to steady amber if the plug is tapped, but goes back to flashing. It will not hold a charge on a new battery.
Dec 28, 2010 | Dell Axim X51v Pocket PC
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
Bettery problem
It could be the battery is already degraded. If the battery is more than 2 yrs. old you could check the battery health meter and see if you need to replace it. Hope this helps
Dec 30, 2009 | Dell Inspiron 1420 Notebook
Laptop battery charge indicator flashing amber and green
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.The battery is too hot to start charging if the batter15.jpg light flashes alternately orange and green. Disconnect the computer from the electrical outlet and allow the computer and the battery to cool to room temperature. Then connect the computer to an electrical outlet to continue charging the battery.
Regards..
Apr 14, 2009 | Dell XPS M1710 2.33GHz Core 2 DUO T7600...
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Flashing red and green battery light dell 6400
Ok, probably not the battery. With Dell machines, once they overheat to a significant level, it locks an overheating code into the bios, so you will have the light codes at start up. I've had three C840 machines with an overheating issue come through my shop. In order to get the machine working again, you will have to fix the problem that caused the overheating, then there is a download at Dell's site to clear the code. If the initial problem isn't fixed the code won't clear. On the machines that I worked on, 1- had a hair wound in the fan and the other 2 had bad fans one burned up the processor. I believe the 6400 and the C840 is basically the same machine. It's been a while since I worked on those machines so I can't remember exactly where the clearing download is at Dell's site, I do remember reading several forums at Dell on the subject. I hope this approach helps a little more than my last. If you have any more questions please ask.
Jul 09, 2008 | Dell Inspiron 6400 Notebook
Dell latitude D600 battery charge light flashing
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Nov 02, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
