Question about Campbell Hausfeld Air Tools & Compressors
Model#wl506800aj serial# L 11/21/2000 01513 electric motor runs ok but trips circut breaker after 1 minute
  • 604 Answers
You are drawing more current then the circuit breaker can handle. find a different place to plug it in, or better yet, switch it to 220 volts, it will run better and more efficiently but of course you will need a 220 outlet, its really worth the time and effort to go 220 volts.
Posted on Mar 18, 2011
Trips breaker
I would suggest looking at the heating element for current leakage
Apr 04, 2014 | LG WM2655HVA 3.6 Cu. Ft. Graphite Steel...
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
Have a Precor M9.1 treadmill which cuts off after about 5 to minutes of use. It can be reset immediately and will run for another 5 to 10 minutes before cutting off again. The belt is well aligned and...
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Repair Parts for 9 1 9 10 Treadmills SPORTSMITH net
Mar 22, 2011 | Precor 9.21 Treadmill
Compressor runs but fan will not. problem started a few weeks ago. would not start while it was raining. it would trip circut breaker. after a day or two of sunshine unit would start and run ok.
sounds like water is getting into the fan and one it has time to dry out its starting again check electrical connections and motor body for any signs of water damage
Jan 20, 2011 | Dometic Rooftop RV Air Conditioner
The circut board was replaced everything powers up lights jets the digital display all program functions to program filtering cycle.while running operation seems normal.after aprox.from start of system to...
Do you have a model and serial number so i can spec components and a diagram?
The reset is a GFCI electrical or a high limit temperature switch?
If its a GFCI you have a leak or a short or the pump is drawing to many amps likely due to something in the impeller or plumbing restricting flow. Potentially its a shaft seal issue.
How hot is the tub when it trips? Try running it cold and see if it trips. If it doesnt and its still cold its the pump. If its hot and you set it to cold its a stuck relay or contactor or triac and therefore tripping a high limit switch.
If this is a hot tub/spa the pressure switch may be an issue. It shuts down the heat typically and keeps the pumps running.
If a reset switch of any type is tripped to many times it will continue to trip at a lower and lower value.
Just some tips, hope they help. Get back to me with some info.
Jan 20, 2011 | Home
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
Dry trips breaker
breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Sep 18, 2017 | KitchenAid KEYS750LQ Electric Dryer
Air Tools & Compressors Logo
70 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
