Question about Ricoh Aficio 3025 All-In-One Laser Printer
Where can I find directions for using the scanner feature?
  • Ricoh Master
  • 4,340 Answers
Ricoh has the manual online. The scanner wants to scan to a folder that has been SHARED, on a computer somewhere. This setup happens easiest by accessing the printer from a computer, rather than the input pad on the machine. the address will be similar to http://192.168.xx.x/web/user/en/websys/webArch/mainFrame.cgi, and this address goes into the address bar (NOT search) of your browser.
The directions in the Ricoh manual will give you the specifics....
Posted on Mar 18, 2011
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See http://www.afterdawn.com/software/cd_dvd/dvd_tools/frcaspi.cfm for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
Why doesn't the scanner feature work??
What error do you get? What OS is the computer running? Is the scanner lock in the unlocked position? The switch is just below the control panel on the left. Do you have the full-featured software installed? Software is available at http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PRN_LSR_1600N&os=WW1&osl=en&catid=&impid=, just choose your OS. Try a new data cable and a different port. Is the printer attached to the network or used as a local printer via USB? With USB, a bad cable will get the scanner to fail since the scanner requires bi-directional communication. The full-software is needed for most OS versions, not a generic driver. The scanner uses a TWAIN compliant driver for most OS versions but the software includes a WIA driver in Windows XP.
I hope this helps.
Jun 22, 2010 | Dell 1600n All-In-One Laser Printer
Printer works but scanner does not how do i install
First, make sure you have the full-featured software installed (for older OS versions) - see here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=351112&
Second - how is the printer connected to the computer? If you are using a USB cable, try a new USB cable and try connecting to a different port. If you have a USB hub or print server connected between the printer and the computer, try a direct connection. Scanners require bi-directional communication and are more sensitive to data loss issues than the basic printer features.
I hope this helps.
Apr 22, 2010 | HP Officejet 4215v All-in-One Printer
PRINTER IS WORKING BUT I CAN'T USE THE SCANNER
Did you install the full featured software or the generic drivers from the OS? What OS do you have? Get the full software here:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=12999&product=EKN035324
Depending on the OS, the generic driver may not support all of the features of the all-in-one. (That's why the directions say to install the software before connecting the printer to the computer.)
Other issues: Try a new USB cable and plug it into a different port. If you are using a print server or USB hub, try directly connecting to the computer. The scanner requires bi-directional communication with the computer and thus is very sensitive to anything that could interrupt that signal.
I hope this helps.
Apr 13, 2010 | Kodak ESP 5 Printer
Why can I not scan? Press Scan on Printer "No Scan Options"
What OS are you using? Do you have the full-featured software installed? Does the computer see the device properly? Scanners are extremely sensitive to anything that disrupts the bi-directional flow of data. So try a new cable and plugging into a different port (if using a hub or print server, connect directly to the computer). Try initiating a scan from the computer and see if that works.
If you do not have the full-feature software, the buttons on the scanner will not work.
I hope this helps.
Apr 05, 2010 | HP Officejet 4315v All-In-One InkJet...
Similar problem trying to install HP Scanjet G3010 on Vista 32
Are you an Admin user on the computer?
What operating system are you using? XP, Vista, ???
Sep 09, 2009 | HP Scanjet G3010 Flatbed Scanner
Can I scan
go to scanners and cameras in the control panel and double click on your scanner, you should now be able to use your scanner directly without using Kodiak's software.
Aug 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Hp psc 2175 scanner problem
Firmware problem with unit or a stuck keyboard. This is commomn on the PSC series which includes full scanner head failure. Unplug unit from computer to see if it will do it with no cominication to PC.
Mar 28, 2007 | HP PSC 2175 All-In-One InkJet Printer
Ricoh Aficio 3025 All-In-One Laser Printer Logo
257 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
