Question about Stoves 720EF Electric Double Oven
Will not stay on!!! the timer unit has the A symbol showing and unable to get it off, when you try and set the time by pressing the ready time and cook time buttons simultaniously the the minus button the oven turns on but then when the two buttons are released the oven turns off any ideas a hungry mum
  • 250 Answers
You need to check that when you turn the automatic off, there is no time remaining in the cook time. You need to ensure that this is set to zero when cancelling the auto function.
If this still doesn't worh then espares will be able to source a replacement clock for you.
Posted on Jun 04, 2011
Oven keeps beaping and has a alarm symbol showing
Sounds like the timer was set and time is up, the issue is whichever model oven it is has a specific way to stop the alarm. Some just require a simple pressing "cancel" while others use a combination of buttons. I would try pressing either the arrow up or down, if not present just press the "timer" button, see if the alarm symbol changes or disappears
Nov 10, 2016 | Ovens
Stoves 900 ef heritage doubel oven. I cannot seem to get the oven to work as my daughter has fiddled with the clock which has to twisting knobs - one saying cook time and the other saying start time. I...
For the 720ef , this is what you need to do. Hopefully this will translate to your 900.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
To reset the cook time, use the plus and minus buttons to set it to zero.
To cancel the automatic setting and return the oven to manual operation, press the COOK TIME and READY TIME buttons simultaneously.
I hope this helps.
Jul 28, 2011 | Stoves 720EF Electric Double Oven
How do I set the timer?
Feb 23, 2011 | Stoves 720EF Electric Double Oven
Just moved address, new house has a Stoves 720 EF built in oven.Model 059040437. I can't work out how to turn on the grill or set the timer, don't understand what any of the symbols on the front left next...
I don't know if this will help. For the 720ef , this is what you need to do.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Jan 10, 2011 | Stoves 720EF Electric Double Oven
Moved to house with a Simpson Neptune oven (analogue clock)
Try this. For the 720ef , this is what you need to do.
Jun 17, 2010 | Stoves 720EF Electric Double Oven
Set clock for stoves efa 700h
Jan 24, 2010 | Stoves 720EF Electric Double Oven
I need the instructions for a diplomatic double fan oven as the second oven is set on auto timer and I can't get it to work.
i had the same prob..... manual operation, to set the programmer to manual (cancelling any auto setting),press the cook time and ready time buttons simultaneously.
To set time of day, press the cook time and ready time buttons simultaneously and keep the buttons depressed. Use the plus and miuns buttons to the the time. A(auto symbol goes out cookpot symbol comes on.
Mar 27, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
The top and fan oven keep going off because of the timer. I dont know how to get rid of the timer a I never use it. But I donbt want it to cut out th overn which it is doing. Hel,p and info please
There are 5 buttons next to the clock. From left to right they are:-
Minute Minder, Cook Time, Ready Time, Plus and Minus.
It sounds like the timer needs setting back to manual, so to cancel the automatic setting and return to manual operation, press the Cook Time and Ready Time buttons simultaneously.
To cancel any remaining cooking time left on the clock before the alarm sounds, press the Cook Time and Ready Time buttons simultaneously.
If you are interested, to set the time of day, press the Cook Time button and the Ready Time button simultaneously. Then use the Plus and Minus buttons to set the required time.
To set the Minute Minder, press the Minute Minder button, then use the Plus button to set the required time. You can cancel the minute minder at any time by pressing the Minute Minder button and the Minus button until the display returns to 0.00.
To select an alarm tone, press the Minus button to listen to the first tone. Release the Minus button and press it again to listen to the second tone etc. Releasing the Minus button after the tone has sounded will automatically select that tone.
Hope this helps.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Automatic button on lower oven
This is how I reset my U1420NOGB/FD7907 NEFF double electric oven that I inherited also without an instruction book.
There are 4 buttons in a row and then a timer knob that moves left and right.The first button is black,second has an arrow,,third has an arrow and fourth a hand symbol on it.Hold down together, the black button and the arrow button next to it.Without releasing either,twist the timer knob clockwise(to the right)until correct time is showing.Do not release the other buttons at all ,until time is ok.If you miss correct time keep going ,dont go backwards.When time is correct,,release black and arrow buttons and auto will stop flashng ,and oven work.If auto doesn,t stop flashing at this point press the button with hand symbol (manual)on it once.
Aug 27, 2008 | Ovens
Stoves 720EF Electric Double Oven Logo
127 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
