Question about Avanti W1092F Front Load Washer
I need to know what goes in what compartment for the detergent, softner and bleach. I do not have handbook
    Brigadier General:
  • 6,277 Answers
Manual first!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Which tray?
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Cheers,
John C
Posted on Mar 18, 2011
My LG washer machine will not rinse thru the softer section in the cup, what can I do?
then the solenoid is not actuating to allow water into drawer. take top off, very easy, two screws in back, pull back, lift off. follow hose from softer cup to little round device/solenoid. check wiring. check hose, tho you would know there was a problem with hose, because you would see a water leak. replace solenoid. hope this is the issue. good luck.
Mar 02, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Which side of the dispenser does the detergent go?
The detergent goes in the front left side,their is a blue cup their if using liquid,pour it into that cup,if using powder detergent remove that cup and the powder goes there. The Bleach would go behind the detergent& and softner would go in the right rear compartment
Gene
Aug 21, 2011 | LG WM-2277HW Front Load Washer
I don't have handbook and I need to know what products, detergent, softner and bleach goes in what compartment.
This time 'which tray' first! (I have these pre-typed!)
Now manual
Cheers,
John C
Mar 18, 2011 | Washing Machines
When to add softner during wash
Hello, the softener is added during rinse circle but bleach needs to be added at the beginning. First add the detergent, then let the water get it nice and sudsy, then add the bleach then the cloths. It is when you get to the rinse circle that you add the softener.
Thanks
May 22, 2010 | Whirlpool Inglis IP4400 Washer
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
We buy a use front load wacher we dont have the manuel it is a 24 inch front load we dont know if we use the same detergent ad softner and were we put it please sent me or phone me 72 581 0294 or e mail...
Any detergent that says "Automatic" should be OK.
Pretty much any softener should be OK.
You will usually find a drawer on the front panel of the machine, just under the top edge, typically on the left hand side.
If you open this drawer, you will find it is divided into a number of (typically four) compartments. There will be one or two large compartments for detergent and one or two smaller, usually partially covered, compartments for bleach and conditioner.
You need to identify which is which.
Starting with detergent: If you only have one large compartment, that's the one to use.
If there are two, you need to know which is for main wash and which is for prewash. If one is bigger than the other, use the big one for your main detergent load. If using a cycle that does a prewash, put detergent in the smaller compartment as well.
If they're both the same, you need to experiment: Select a wash cycle that doesn't do prewash. Turn the machine on, and when it starts to fill, cautiously open the drawer a little and look to see which compartment has the fill water running through it. That's the one you need to use for your main wash detergent (use the other as well on cycles that do a prewash).
Now look at the smaller compartments. Hopefully, they'll be marked with a triangle for the bleach and something looking like a flower for the conditioner. If not, put a little bit of conditioner into the bottom of each, set the machine to "final rinse" and see which compartment it takes the conditioner from. That's the one you use for conditioner in future. (Don't worry about the little bit of conditioner you've put in the bleach tray - this will rinse out the first time you run a full cycle).
When putting in bleach or conditioner, it's important not to overfill. If there's a fill level line, don't go above that. If the compartment is covered with a grating then fill no further than the grating. Overfilling will cause the product to go into the machine too early in the cycle.
(Finally, strongly advise against posting your phone number or personal email address on public internet sites - it attracts all sorts of undesirable attention)
Good luck - and enjoy your new machine.
A.
Mar 15, 2008 | Washing Machines
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Avanti W1092F Front Load Washer Logo
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
