Question about Toyota Sewing Machines
I have been sewing bunting for a copule of days without trouble. When I changed my bobbin and spool, the bobbin thread gets caught up and makes a mess and stops the machine. Also, the bobbin case doesn't sem to fit in the machine properly, though it fits alright without the bobbin in the case.
  • Anonymous Mar 28, 2014
    i have aquired the above machine but cant seem to get the spool and black spool case to stay in the machine. i would like to know if i can get a replacement spool and case to fit
    Scholar:
  • 89 Answers
Is this a top loading bobbin case? If so take the stitch plate off and look for burs or needle punckers on the bobbin case, if you find some polish them off(may need to be replaced.
Also did you use the exact same bobbin that you took out, just had a customer come it that was using the incorrect bobbin for her machine.
Also check your top threading, sounds like it could be that. Make sure to get it in the tension unit. Thread the machine all the way to the needle but not in the needle eye. Then lift and lower the presser foot, you should have tension when it is down and no tension when it is up. If not your machine needs adjusting.
hope this helps
Posted on Mar 18, 2011
Machine sews for 1o seconds and stops
without seeing the machine, here are my suggestions
try a new needle
rethread the machine--make sure to use every thread guide
make sure the top thread does not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted correctly into the bobbin holder
make sure the thread is not caught on the spool pin
also could be a computer motherboard problem
Feb 15, 2014 | Singer CE-200 Quantum Futura Computerized...
Thread keeps breaking
have you tried changing the top thread tension
also rethreading the machine, that way you can make sure the thread is not caught on anything
also make sure the thread is not caught on the spool pin
also try a different thread
also try a different needle---just in case it might be damaged
Aug 29, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Why does my thread keep breaking and why wont the sewing machine stich?
sometimes the thread can get caught on the spool pin
or on the notch on the thread spool itself
on some machines the thread can come off the thread take up lever
it can also get caught in the top tension area
also check your needle to see if it's bent--roll on flat surface to see if it rolls correctly
there are 3 types of bad needles-bent
blunt--makes a popping sound when going thru fabric
damaged--broke tip
also check your bobbin area for lint or loose threads
check your bobbin to see if it's warped--I've come across some that were warped
check your top thread tension
Sep 24, 2010 | White Sewing 2200 Multi-Tasker
I am totally new to machine sewing and I have a Husqvarna Model 400, its been working perfect then suddenly when sewing the thread from underneath (the spool side) is just coming out in huge clumps, the...
When you say "the spool side" I assume you mean the bobbin. There are a couple of reasons why this could be happening. First re-thread your upper thread with the presser foot up and check to see if the top thread is firmly in the tension disc. Usually when you have looping of thread on the underside of your fabric, it is the upper thread that is out of whack. Just the opposite of what you would think! When you're sure the top thread is right check your bobbin to make sure that's wound tight and not "mushy." When you start by wrapping the thread around the bobbin by hand and then put it on the winder to fill it, it is not tight enough so the whole bobbin winds too loose. This can cause clumps underneath. The last thing to check is that the bobbin thread is caught in the tension slot in the bobbin case and that there is no stray threads in the bobbin case opening to cause trouble. Hope this helps. Good luck. You have a great machine!
Sep 10, 2010 | Husqvarna Sewing Machines
Thread bunches up in the bobbin area and needle appears to be stuck and won't move. Almost like the thread wont come off the spool.
Check to see if the thread coming off the spool is tangling on the spool pin or getting caught in the crack on the spool top where the thread originally comes off spool. Make sure the spool pin is pushed all the way to the right to secure your thread and then back it off slightly so the thread pulls evenly off the spool. Whenever your bobbin thread gets bunched it is usually something is wrong with the threading of the UPPER thread and vice versa. Let me know if this solves your problem.
Aug 23, 2010 | Brother XL-5500 Mechanical Sewing Machine
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
My machine has just started having a problem where the top thread is getting caught on the bobbin instead of clearing around it. This means I end up with many threads coming up from around the bobbin....
check to see if your needle is bent-roll it on a flat surface to see that it roll good
check to make sure the thread is not coming off the thread take up lever
check in the bobbin area for lint or loose threads
check to make sure the thread is not getting caught on the spool, sometimes the notch on the spool can catch the thread
check to make sure the thread is not winding around the spool pin
Aug 10, 2010 | Husqvarna Sewing Machines
I am having trouble with my bobbin . When I put into the sewing machine and begin to sew the cotton just bunches up and jams . Any suggestions
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
Hope this helps.
Sep 13, 2009 | Husqvarna Designer I
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
sew.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Sewing Machines Logo
75 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
