I have a plotter HP Designjet T610, which I have been making mistakes as I indicated in the instructions, but the error persists, it's 79:04 and I've tried the steps mentioned, such as turning off the computer and re-turn it on, but even so, I have a good result. Nor let me use the options menu board plotters. Greetings, I hope and I can help with a good response.
  • 141 Answers
I would like to add to the Baron's response, and tell you that a 620n Jetdirect will probably fix your problem, BUT you may be sending a corrupt file, or the driver is corrupt. The worst case scenario is an E-mod (electronics module). I would agree that 615n cards are ****, and should be eradicated from the planet.
Posted on Jul 29, 2011
  • 1,915 Answers
The 79.04 error is usually caused by an IO port such as parallel or ethernet. If you have an ethernet port in this printer it is likely in the form of an HP JetDirect card. Turn printer off, remove this card and restart and your error will likely be gone. If the card has a model # 615N, throw it as far away from your printer as you can and buy a new card.
Posted on Mar 19, 2011
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
I have hp t610 plotter and it incurred paper jam
Check the carriage belt for wear. Is there an error code?
Aug 19, 2013 | HP Designjet T610 InkJet Printer
Trying to connect a hp designjet t610 to a network using a usb
You cant from a network on a USB connection. USB connections are for "local" printers. "add" the Designjet T610 printer to your other PC under "printers and devices" tab. Good luck !
Feb 19, 2013 | HP Designjet T610 InkJet Printer
My plotter is saying that there is an error, number 87:10 What is this, and what can i do do? Its a HP Designjet T610.
The printer is having a problem finding the Scan-axis encoder reading.
Start by upgrading the firmware. Go to www.hp.com. Go to Support and Drivers.
Enter your printer model, select your operating system, select firmware.
Follow the directions.
If that doesn't fix the problem, clean the encoder strip( the flat metal strip that runs the length of the printer).
If the problem persists, someone trained on DesignJets is going to have to look at it.
Hopefully, the firmware will fix the problem.
Mar 23, 2011 | HP Designjet T1100ps Printer
Mu HP Designjet T610 get mistake 21.13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Aug 05, 2009 | HP Designjet T610 InkJet Printer
Error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 18, 2008 | HP LaserJet 4 plus Printer
252 people viewed this question
jasbo
jasbo
