Question about Refrigerators
Stopped cooling defrosted and fan still runs help!
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Testimonial: "After reading your solution, my 16 year old son was able to fix our fridge that had stopped cooling. THANK YOU! Saved me a fortune."
4 Suggested Answers
  • 61 Answers
SOURCE: kenmore side by side 59658692890
you kenmore may be held up in defrost . you ll nead to lokate the timer and first try turnig it with a screw driver. sugjest it may be lokated in behind the covers at the rear of the food compartment .
amana is a totaly diferent unit excepy the 9 year old model . lokate you timer as well but you say the compressor runs. if the copressor runs and there is no cold then the must be eather a leak of refrigerant total loss . or inoficient compressor. eather case the fridge this problem is way to expensive to repair and out of woranty. sorry.
kenmore if the timer wasnt the problem now you look at the temp control . it is the one that actualy has an off position. you can try a hard tap with the handle of a screw driver and see if the compressor starts , if not you have to olm it out and see if it has condinuity in the on posision. hope this helps
Posted on Oct 20, 2008
wheelshot
  • 102 Answers
SOURCE: the fridge is not defrosting and the fan inside is stoping
One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, is measures open bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
Posted on Apr 02, 2009
ginko
  • 19396 Answers
SOURCE: Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Posted on Dec 09, 2011
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
Refridgerator section of side by side has stopped cooling, removed coil cover, fan was covered in ice, is there a fuse somewhere for fan
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Mar 14, 2011 | Samsung Refrigerators
Fridge defrosts but drain eventually freezes up and stops fan
heatman101
Jan 03, 2011 | GE GDS18LBP Bottom Freezer Refrigerator
Fans making noise but stop when upper doors are opened, frost built up in freezer area where fans are
heatman101
Dec 09, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge fan has frozen and has stopped. was noisey and stopped when door opened
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 12, 2010 | Samsung RS2534 Side by Side Refrigerator
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
heatman101
Sep 16, 2010 | Amana Refrigerators
Cooling and freezing problem
When the frig stops cooling properly, is it running at all? If the freezer fan is running and it is not cooling, you can rule out the thermostat and the defrost control. It would be a hard starting compressor or condenser fan. If the frig is not running, then it is likely the thermostat or your electronic defrost control. The defrost control is right behind the thermostat in the same housing. When you play with the Tstat, do it carefully as not to jar the defrost control. If the frig comes on, replace the thermostat.
Mar 23, 2009 | Kenmore Refrigerators
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
265 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
