Question about Cell Phones
What does a tracfone code 34 mean? When it occurs the phone will not receive a call or make a call. Another different tracfone physically next to it operates normally.
  • jedlickara Mar 18, 2011
    Your solution seems to help. I have contacted Tracfone and have gone thru a resetting procedure. Only time will tell now if this all works. I think you solution was adequate. Thank you.
  • 5,081 Answers
Call customer service at 1-800-867-7183. The problem is with their signal reception. they will either check if any of their settings is changed or else they will send a new sim card if the sim is damaged or not receiving signals properly. The sim will be sent for free of cost.
Posted on Mar 18, 2011
Why do i always get the service unavailable notice no matter where i try and use my phone?
Complain to Tracfone and ask what their coverage is where you live. I am guessing you are in an area at the edge of their coverage or you are in a 'dead spot'. Or the phone could have a faulty antennae.
Mar 09, 2016 | KVH Tracphone Fleetbroadband 250 With M5...
I try to call my safe link phone says check call restrictions 34,how to I fix this!
Did you make at least one call per month on the tracfone? If not this maybe one of the reasons the call is restricted. You may have to manually receive your minutes for the month by: Pressing the menu key, when the prepaid menu appears press select. Go to redeem airtime or add airtime. If your screen displays a message scroll down and press ok until you see Card# or Airtime Pin. Enter 555 then press enter. If it says promotional code select no. Make sure you keep your safe link phone on to receive your minutes and see if that fix the problem. If that doesn't work you may have to call safe link at 1-800-378-1684.
Best Regards!
Feb 25, 2015 | Samsung Tracfone Sgh T105g Cell Phone...
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
On a Tracfone, what does ''check call restrictions -34'' mean
it means that you have moved areas of where you initally activated the phone in (city, state) and your new area support a better technology or better carrer.
main carriers t.f. use are vzw, at&t, t-mobile. most of the time GSM phones will display call restriction so u could get a cdma phone instead.
there is like 20% chance to fix it but all in all, u'll get either a new SIM card or phone of different technology.
any tracfone questios, email starfire2k4@yahoo.com
Jan 21, 2010 | Motorola Cell Phones
I have a Motorola W260G Tracfone and I'm getting a "Restricted Number - 34" message all of a sudden. What is this about?
Had a similar problem on my V170. Remove the battery and the sim card. Using a q-tip dampened (not dripping wet) with rubbing alcohol, clean the metallic side of the sim card and allow to air-dry, then wipe once more with a dry q-tip. Do the same for the metal terminals in the sim card slot if visible. Go ahead and clean the battery's contacts and the ones in the phone while you're there. Put it all back together and try again. This will fix most sim-card problems as long as there's no physical damage.
Good Luck
Jim
Aug 03, 2009 | Motorola Mobility TracFone® V170 Cellular...
Check call restrictions 34 cant make any calls
Just turn off the set, and turn it on again. It solved on my tracfone service. Good luck!
May 29, 2009 | Motorola Mobility TracFone w175 PayAsYouGo...
Call restriction
ALL YOU HAVE TO DO IS DELETE SOME OR ALL OF YOUR DIALED CALLS.
Dec 29, 2008 | Motorola Mobility TracFone® V170 Cellular...
Cell Phones Logo
273 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
