Router dropped connection and is now no longer discoverable. Wireless light is not on, power and internet lights flash. On reset power light flashes red but does not reboot. It is connected to pc using lan cable but has limited connectivty and i also cannot log onto the router itself
  • 79 Answers
You just have to restart the router it self. i mean take out the power adapter and plug it back. No need to press the reset button as it may put back the router to factory default.
These kind of issues are common. The DHCP service (which gives IP to your computer and wireless device) hangs up some times on most routers.
Let me know if you still face the problem after power cycling the router.
Posted on Mar 18, 2011
Flashing WLAN LIGHT ON EDIMAX ROUTER
No, it means it cannot set up a Internet Connection.
Try Powering Off and On again, if not contact your Internet Supplier.
Jan 27, 2013 | Edimax WiFi 150Mbps ADSL2 Modem Router
When i plug my dlink DSL-2640U router the lights start flashing and every time it flashs the wireless just drops down and i have to enable it from the settings .. then the router's lights flash an
The led always flash with activity. They are transmitting and receiving data. If they stop flashing your ISP signal has stopped. Could you explain this statement" the wireless just drops down and i have to enable it from the settings"?
Dec 20, 2012 | D-Link Computers & Internet
How can i reset my Belkin Wireless G Plus MIMO Router it cannot connect for an internet connection
  • Locate the small master-reset pinhole on the back of the router. The pinhole is located directly to the right of the Ethernet port labeled "connection to modem."
  • 3
    Soft-reset the router by placing a sharp object, like a push pin, into the router hole. Push inward and immediately release the button. The lights on the router will flash and then the "Power/Ready" light will start to blink. When the light turns solid, the router is reset and ready to use. This reset does not restore the router to factory settings. It refreshes the software and is similar to rebooting a computer. If you want to restore the router to the factory settings, skip this step and move to step four.
  • 4
    Master-reset the router by placing a sharp object, like a pushpin into the router hole. Keep the pin pushed into the hole for 10 seconds. The lights on the router will flash and then the power/ready light will start to blink. When the light turns solid, the router is reset and ready to use.
    Read more: How to Reset a Belkin Wireless G Plus MIMO Router ' eHow.com http://www.ehow.com/how_6759000_reset-wireless-plus-mimo-router.html#ixzz16uTbPLCW
  • Dec 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Linksys Router lights just flashing
    Try doing a hard reset for 1 minute (longer) then powercycle... there should be a miracle* :)
    Mar 07, 2010 | Linksys (WRT54GC) Router
    I check all connection, all wires and internet connection and the port leds lights do not light on, why?
    If when you plug in the power you get the Post light flashes and then no lights you may need to do a hard reset of the router.
    If you get no Post light flashes when you plug in the power then your router power supply is most likely the culprit.
    Cheers,
    Ron
    Jan 18, 2010 | Linksys Wireless-G WRT54G Router
    My Belkin N1 router can't seem to establish connection with the cable modem - the router light flashes and connects but as the internet light flashes it loses the router light again. It is still allowing...
    the modem is working fine. the connection might be dropping from the router side.
    You can try to upgrade the Firmware of the router.
    reduce the MTU on the router. If it is on 1500 the reduce it to 1400.
    Click Here from more info about routers
    Oct 31, 2009 | Belkin (F5D8231-4) Wireless Router...
    Power light flashing green
    the green power light is flashing green with the orange tick next to it and i cant get any wireless internet through it what do i do please help me
    May 15, 2009 | NetGear DG834G Router
    Netgear WGR614 v6 router drops connection
    Hi, what ISP are you using (aol,tiscali...?), and how are you connecting to the router? Wired or wireless? I had similar problems with mine, it wouldn't connect or would drop connection, or loose all the settings. I updated the firmware to the latest from here:-
    http://kbserver.netgear.com/products/WGR614v6.asp
    Be sure this is the correct model as firmware differes from model to model.
    Then I had to manually configure my ISP settings etc. Or you may have software from your ISP which configures for you.
    Hope this helps.
    Jan 22, 2009 | NetGear WGR614 Wireless Router
    Wireless printer stopped printing-wireless router light flashing
    Restart your Printer so that it can Look for the Connection again, if you havent done this already.
    If this doesnt assist in the problem, please give me the complete Model Number for your printer so i can find the solution
    Jan 14, 2009 | NetGear WGT624 Wireless Router
    Netgear
    There are two things involved in getting disconnected either your comp is getting disconnected or your router.
    Instance 1
    Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
    Instance 2
    Router getting disconnected...
    Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
    Apr 22, 2008 | NetGear WGR614 Wireless Router
    Computers & Internet Logo
    127 people viewed this question
    David Payne
    David Payne
