Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Vacuum is not picking up , there is nothing in the collection bin, it is running but not picking up.
  • 1,998 Answers
You need to be able to determine if you have any suction at all or even weak suction if you had weak suction you would take all the hoses off and check for a blockage in the hoses if you have no blockage then you could be having a problem with how much power is coming out of the motor or it could also be the fan located on the inside that has broken you would have to disassemble the unit in order to find out which is causing your suction issue check all the hoses first then message me back with your finds Thanks Rick
Posted on Mar 18, 2011
  • Rick Ead
    Rick Ead Mar 18, 2011
    if the unit is still under warranty do not try to repair the unit this would cause your warranty to be voided I await your reply Thanks Rick
  • Rick Ead
    Rick Ead Mar 19, 2011
    and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
The dust collecter is stuck and won't release from the vaccum. how do i release it to empty.
Make sure you switch off the vacuum cleaner.
Here is the instruction to remove the bin
Press the cyclone release catch with your thumb to remove the
clear binTM assembly from the machine.
• When removing bin, do not pull up on carry handle while pressing cyclone release catch
• When replacing the bin, ensure it clicks back into place.
Dec 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I misplaced manual for Bissell Bagless Cleanview II, nothing being picked up in the plastic bin, where to I look for clog other than bottom of hose near bottom plate please?
Recline the vacuum fully to the floor when looking for clogs in the lower hose. You can run a broom stick through the upper hose to remove any clog. Also, check the brush to make sure there is no obstruction. Lastly, make sure all 3 filters are clean and clear because if they are dirty that can restrict air flow drastically. You can purchase filters at www.bissell.com
May 29, 2011 | Bissell Cleanview Helix Deluxe Bagless...
My Eureka 5892 BVZ-1 vaccum has very little suction. I checked hoes and emptied cup, and made sure filter is not dusty.
There are probably three filters, one on the back of the dust collection bin, one under the dust collection bin, and one where the air exits the vacuum, check all three.
Gary
Mar 04, 2011 | Eureka 5892AVZ Bagless Upright Cyclonic...
Clogged sweeper filters changed and hose cleaned, but no dirt collecting in the bag. I am no sure what do do next
You have a rubber flap in the dust collection bin that may have been pulled out causing the collection bin to close when vacuum tries to pass through. Try pushing the flap back in to see if that's the cause of your vacuum loss. To test if this is the cause try turning the cleaner on and feel the outlet leading into the removable bin to see if there is any air flow. If there is no air flow, unplug the vac and run a coat hanger through the inlet tube to find and clear any obstructions. Then take the vacuum outdoors, plug it in and turn it on to clear any dust or debris left in the vacuum chamber.
Mar 15, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
My roomba 560 works perfectly for a year. Now works ok, vacuum but the dust stays at the bruches and at the bin. i replace the filter but nothing. Thanks George
You need to decide if the vacuum and brushes are runing or not. For me its easy to determine after its run. If the brushed turn then I have debris in the open part of the collection bin when I pull it off the back, but none if the brushes don't turn. If the vacuum runs then there is dust at the filter, and none if it the vacuum doesn't run.
You can also remove the vacuum/bin and place the roomba on a hard floor and start it and look into the rear and see if the brushes are turning.
When the vacuum is running there is a noticeable amount of air pushed out the rear vent.
When you've figured out what isn't operating, you'll be halfway to solving your problem.
Nov 30, 2009 | iRobot Roomba 560 Robotic Vacuum
Not sucing
The reason it is not picking up is probably because the belt is stretched, worn or broken and is not turning the brush the way it should and therefore not picking anything up. You should change the belt on your model at least once a year. Here is a link to the belt you need and a link to the owners manual which has belt changing instructions:
Eureka Capture Replacement Belts
Eureka Capture Owner's Guide
Nov 08, 2009 | Eureka Capture Upright Vacuum Vacuum
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba Discovery
did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Oct 02, 2008 | Roomba Robotic Floor Bagless Vacuum
DC07 cylone not cycloning
Hi Michele.
The yellow tube with the fins on does not spin. So that is fine.
If you have pets or lots of fluff vacuumed up it may not roll around in the waste bin when using this is normal & nothing to worry about.
Just empty bin & start cleaning you will see the grit particles spinning but as you collect fluff or hair that may roll around at first but as more is sucked up it will stay still.
http://dysonmanuals.llc.nu/
Mar 21, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
44 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
