Since the heater has continuity it is good and does not need to be replaced, the other parts that can make a ref. not defrost are the defrost thermostat or the defrost control (mother) board.
To check the defrost thermostat it must be checked when cold,when cold it should have continuity on it. The defrost thermostat is in the freezer clipped to the TOP of the evaperator coil usually on the right side...this is what it looks like
If the defrost thermostat has no continuity when cold it is bad and thusly the problem...if it is good and has continuity and already having determined the defrost heater is good..the problem is going to be the motherboard since a part of it is the defrost control.it is the back of the ref.on the left.
The part numbers are
DEFROST THERMOSTAT...... WR50X10068
MOTHER BOARD..... WR55X10942
