Question about Feenix Indian Motorcycle
2000 indian chief will not start. clicking and slow turning starter
2009 Indian Chief Vintage will not turn over
Hi, Johnny before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2014 Vintage Won start in the Cold
What to do When Your Motorcycle Won Start
Indian Motorcycle Chief Classic Service Manual
Indian Chief Vintage Parts
Indian Motorcycle Chief dark horse Owners Manualual
Jan 19, 2018 | 2009 Indian Chief Vintage
Will the engine from a 2015 Indian Chief fit a 2000 Indian Chief?
Hi, Peter the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
New Forum Section Gilroy Era Indian Specific Forums
Amazon com Customer Questions Answers
Featured Products
Indian Motorcycle Roadmaster 2015 Rider Manual
Sep 30, 2017 | 2015 Indian Chief Classic
2014 Indian Chief Classic cuts out while riding
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Engine cutting out on the move
Engine Cutting out misfires
Motorcycle Service Parts Part Finder Indian Motorcycle Store
Indian Motorcycle Chief Classic Rider Manual
Aug 12, 2017 | 2014 Indian Chief Classic
Need wire diagram for roadmaster 1000
Hi, Jeromy for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Indian, despair not, for a mere $12 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Indian roadmaster 1000 wiring diagram Google Search
INDIAN MOTORCYCLE CHIEF ROADMASTER SERVICE REPAIR PDF MANUAL DOWNLOAD 2009...
http://polaris.hs.llnwd.net/o40/ind/2017/documents/manuals/9926788r01_lo_res.pdf
Indian Motorcycle Chief Classic Service Manual FREE
Oct 06, 2016 | Motorcycles
Does the 2011 Indian Chief Roadmaster have a cam shoe tensioner problem? @
Hi, Janet the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
http://www.indianmotorcycleforum.com.au/post/stage-2-camshafts-my-impressions-8119939
TS111 cam chain tensioner wear after 32 000 miles
Jan 24, 2015 | 2011 Indian Chief Roadmaster
2011 Indian Chief Roadmaster motorcycle cam chain shoe tensioner problem @
Hi, Janet for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Indian, despair not, for a mere zero $0 you can download another one.
2011 Indian Chief Roadmaster motorcycle cam chain shoe tensioner problem...
2014 Indian Chieftain power windshield fuse location
Hi, Kathy for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Indian, despair not, for a mere $15 you can download another one.
Fuse help
2014 Indian Chieftain power windshield fuse location Google Search
Oct 07, 2014 | 2014 Indian Chieftain Base
Ask jeeves
Indian Motorcycle Company (2006-2011)
Indian Motorcycle Company 220px-indian_motorcycle_logo.svg.png Type Subsidiary Headquarters Medina, Minnesota, USA Key people Stephen Julius
(chairman)
Steve Heese(president) Products Motorcycle, Accessories,Apparel, and Gifts Employees Parent Polaris Industries Website www.indianmotorcycle.com 220px-indian_motorcycle_2.jpg magnify-clip.png
Stellican Indian in characteristic Indian red colour in Brighton (UK) On July 20, 2006, the newly formed Indian Motorcycle Company, owned largely by Stellican Limited, a London-based private equity firm, announced its new home in Kings Mountain, North Carolina, where it has restarted the Indian motorcycle brand,[48] manufacturing Indian Chief motorcycles in limited numbers, with a focus on exclusivity rather than performance, like a "luxury" watch. Starting out exactly where the defunct Gilroy IMC operation left off in 2003, the "Kings Mountain" models were continuation models based on the new series of motorcycles developed in 1999. The 2009 Indian Chief incorporated a redesigned 105-cubic-inch (1,720 cc) Powerplus V-twin powertrain with electronic closed-loop sequential-port fuel injection,[49] and a charging system providing increased capacity for theelectronic fuel injection.
Aug 14, 2014 | 2009 Indian Chief Roadmaster
Cadillac 2004 cts, wont start
i had a 2003 ctc that did the same thing, it wouldn't start or would make a clicking sound and about 1 mth after the problem started aND mechanics could not find a problem my car caught on fire and burned completely from something under the right side of the hood. i had just parked the car and got out, it happened really fast. the fire chief said the cause was unknown????
now i have a 2004 cts and i'm having the same problem!!!!!!!!!!!!!!! has anyone else had this happen???? please be cautious if your cts is doing this, during the fire my doors locked and had to be pried into by fire chief.
Nov 24, 2008 | 2004 Cadillac CTS
Feenix Indian Motorcycle Logo
182 people viewed this question
Top Feenix Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Feenix Toy Expert? Answer questions, earn points and help others
