Question about Ford 1932 Ford Two In One Model Kit 118 By Gmp
Hello, I bought the 32 ford model kit from Gmp but the instruction manual was uncomplete. the only part that was described is the steering mecanism. i want a manual for the whiring of the engine. (ardun head flattie with blower). sorry for my bad english. gr
    Problem Solver:
  • 6 Answers
Hi there yes thats all you get if you read the boz it will say the instructions are brief and that you need to have a good knowledge in 32fords and hotrods i studied loads of pics for mine and when its done with an exelaxant paint job its a very rewarding model.
just think that the manufacturers in china they have the same instructions as you get, a few pics they have to learn to build them to.
hope this helps if you would like more on gmp help please do contact me at austintant@hotmail.co.uk put your subject as gmp
Posted on Jul 11, 2011
Yardworks manuals
Hello ford _taur
Copy following link to identify same-similar timer and download possible instruction manual
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add comment and describe timer in detail
Apr 27, 2013 | Hardware & Accessories
2005 GMC ENVOY 4.2L VIBRATION PROBLEM AT IDLE AND START UP OR ANY TIME NO ACCELERATING
Hello! This is a known problem that is addressed by the following Technical Service Bulletin...Guru...saailer
Subject:Steering System Moan, Groan, Shudder and/or Vibration Type Noise During Low Speed Turning Maneuvers (Replace Steering Gear) #04-02-32-007A - (12/01/2004) Models:2004-2005 Buick Rainier
2003-2005 Chevrolet TrailBlazer, TrailBlazer EXT
2003-2005 GMC Envoy, Envoy XL
2004-2005 GMC Envoy XUV
2003-2004 Oldsmobile Bravada
Short Wheelbase Utilities Built Prior to VIN Breakpoint 52123375
Long Wheelbase Utilities Built Prior to VIN Breakpoint 56137280
This bulletin is being revised to remove the 2002 model year and add the long wheelbase utilities. Please discard Corporate Bulletin Number 04-02-32-007 (Section 02 -- Steering).
ConditionSome customers may comment on a moan, groan, shudder and/or vibration noise while making low speed turning maneuvers. Customers usually notice this condition in parking lot turning maneuvers.
Correction
  1. Diagnose the power steering concern. Refer to Symptoms - Power Steering System (SI Document ID #670351).
  2. Replace the steering gear with a newly designed steering gear. See the parts information below. Refer to Power Steering Gear Replacement (SI Document ID #742314).
Parts Information
Part Number
Description
Qty
88965356
Gear Kit, Steering
(Short Wheelbase Utilities)
Gear Kit, Steering
(Long Wheelbase Utilities)
Warranty InformationFor vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E9740
Gear Assembly, Power Steering - Replace
Use published labor operation time
E2000
Toe, Front - Adjust
May 03, 2012 | GMC Envoy XL Cars & Trucks
1987 Ford F-350 Steering Gear Box Seal Leaking. Is it possible to replace the seal to fix the leak?
csk auto parts store has steering seal kits and steering gear shaft input seal kits...as for the replacement procedure, I would recommend having a quality repair manual on hand and do a "dry run" before attempting the fix for real.
Aug 17, 2011 | 1987 Ford F 350
Hello I bought a 8000k hid light kit for my 2011 f-250 lariat can you give me a wiring diagram on how to hook up my lights please .
Follow the instructions that came with the "kit"...they are rated at different wattage and need different amperage requirements.
Jul 25, 2011 | Ford F-250 Cars & Trucks
I purchased a GMP 1/18 '32 Ford kit, and it contained no instruction manual at all. Is there something that indicates the parts list and what sequence it is to be built ? Is there any sort of...
hi there no if you read the box it should say the intructions are breif and you must have knowledge in real fords to build.
i studied about 4000 pictures to build mine and alot of that was for the front axle. when it is complete and if you can spray very well like i can its very awarding.
Jun 28, 2011 | Ford 1932 Ford Two In One Model Kit 118 By...
Need to find user guide and owners manual
Hello;
I have lost the user manual to a Panasonic TX-32LXD700 32" TV. Does any one know of a link to download a copy?
Many thanks to any one who can help?
Feb 10, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Bought Kenmore 796.9044 gas dryer in Dec. 2010. Was told by salesman to wait for dryer to arrive and order my LP conversion kit per the instructions provided with the unit. When I picked it up, I ordered...
It should come with a manual. It does simply installs after removing the other regulator & do use pipe dope too. The orfice is really the only thing needed to change although it is calibrated so it will be fairly easy to change around
Dec 27, 2010 | Kenmore Dryers
What kind of a lift kit can I bolt on my self for my 1996 ford exploer
The easiest lift kit is the body lift kit. You install rubber bushings between the body and the frame. Some trimming of the fan shroud and adjusting the steering shaft. A good kit will have in instructions.
Dec 01, 2009 | 1996 Ford Explorer
Need a diagram how rebuild kit (o-rings & seals) go in pump
go to your local libary and check for a workshop manual on your make and model it is quite an intense job
Apr 25, 2009 | 1994 Ford Tempo
BLUETOOTH FOR FORD CAR RADIO CD PLAYER MDEL NO 2006
You should take it into a Ford Dealership. They can help you use it.
Mar 06, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Ford 1932 Ford Two In One Model Kit 118 By Gmp Logo
155 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
