Question about Samsung TXN2730F 27" TV
Hi I am hoping that somebody could help me out with that samsung TV which i have purchased before 5 years ago, tv having problem regarding all about with sound of tv (model no-CZ-21K5G7 type-KS9A21K5 SVC MODEL CZ21K5G7ZX/XTL ).there is no any sound output in hearing,it just like silent.most of the time picture quality is good but not all the time,, I have already consult with the mechanics but they can't rectified this problem. please help me out as soon as possible rabindra kumar
    Top Expert:
  • Samsung Master
  • 75,581 Answers
Hello
you have given me a detailed description of the fault of your Samsung TV. At first, make sure that the "mute" function is in 'OFF" positon. If it is in "ON" position, no sound output will be there from your TV as you know. If it is alright, switch OFF your set by its mains power ON/OFF switch at its front panel. You have to check this first. Keep your ear very close to the speaker side of your TV, and switch it ON by the front panel switch, and listen, whether there is any "Thumb" sound comes from the speaker or not. If there is sound, it means that the speaker is alright, and the sound output section inside the main board of your TV is faulty. If there is no sound "Thumb" from the speaker, the speaker has got damaged, and should be replaced.
The second step needs some skill in electronic work. You must have a good quality multimeter and soldering iron to proceed. Open your TV, and pull out the main circuit board out, keep it upside down, and check for any loose sodering at the audio output side in the circuit. it is a common fault to all kind of TVs that, loose solderings will occur after a long period of use. heating and cooling of these components in the audio output section will result in loose solderings at the termianals of componets. Just resolder most of the suspected solder point by applying a little more solder over it. Care should be taken not to short circuit adjecent sodler points when do this work. If this does not help you, measure the voltage at the input pin of the audio output IC. If it is found ok, desolder it out the audio output IC from the circuit board, and replace it with same type and number. OK.
Posted on Mar 18, 2011
Samsung LED TV, sound but no picture
Have you tried unplugging it and letting it reboot?
Nov 12, 2016 | Samsung Televison & Video
Samsung UN55C6500 turns off and on at random
ghosts. actually, check your house wiring, for leaks, open grounds, etc.
Feb 01, 2014 | Samsung UN55C6500 55 LCD 1080p HDTV LED...
I have a samsung HLR6156WX. Bought it new 5 yrs ago gets very very little use (guest area). Turned it off and now it wont come back on. Ive read different post about slappint the left side after leaving it...
amount of use does not counter the fact the tv was 5 years old. a blub not used for 5 years can still burn out just like any other bulb. the only thing you can do is get it replaced.
May 02, 2011 | Samsung Televison & Video
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
TV LG FLATRON RZ42LZ30 WHAT WOULD THE PRICE BE OF THIS TV
hi.the set retailed at 1600 gbp around 5 years ago in the uk.hope this helps!!!
regards,steve
Oct 22, 2010 | LG Televison & Video
Greyish marks on Samsung 32'' LCD TV
it should be covered, can call 1-800-samsung for nearest authorized service center or go to samsung.com
Dec 31, 2009 | Televison & Video
Toshiba 32" Model# 32A33 TV About 5 years old
change tact switches
you have windex syndrom
using too much windex cleaning tube
Aug 26, 2009 | Toshiba 32A33 32" TV
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Samsung TXN2730F 27" TV Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
