Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I;\IS NOT ACCESSIBLE ACCESS IS DENIED - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
  • SanDisk Master
  • 27,725 Answers
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
also you might
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 18, 2011
4 Suggested Answers
SOURCE: Local Disk(D:) is not accessible Access is denied
hi , got the problem with my maxtor hard drive
error message is
.D:\ is not accessible
Error performing inpage operation.
done the virus checks driver updates,system restore but nothing works, comp is very laggy when trying to use it, tried turning the power of to the D drive and that fixed the problem with the lag but no cant get into my back up drive which is the D drive.
plz help if u can
Posted on Jun 12, 2008
  • 158 Answers
SOURCE: My 320GB External hard drive is showing access denied when I click on it.
the file you need is called takeownership you have to google for it as it's in one of the forums the file is in the form of a zip file and when extracted you select the takeownership and install a little code into your reg and when you select a folder right mouse button on it and select takeownership this willl get rid of access denied garbage and give you full control over the folder and you do the same on any hard drive.
hope this will solve problems of access denied
Posted on Nov 23, 2008
If access is denied, right click on the drive and set administrator rights to gain access.
Oct 10, 2015 | Computers & Internet
C:\ is not accessible access is denied
Try right clicking on the folder, then go to properties, then the security tab. You may have to change or edit some of the permissions in there.
Feb 03, 2014 | HEWLETT-PACKARD HP Pavilion dv4-2165dx...
Access denied to my all users/Documents
Try booting up in safe mode, log in as the administrator. Then go into the security settings for that particular folder (right click, properties, etc) and check/change the settings. Reboot and try again.
May 22, 2009 | Dell Inspiron 9300 PC Notebook
The hard disk in drive D: is not accessible
Hope I can help you with your problem. If your hard drive was installed to be used as D: in your old computer then you will have to set it up to be D: in the new computer. This may be why it is not being recognized. You can do this by connecting it as a slave on the primary IDE cable.
Also you will need to check the jumper on the hard drive to make sure it is set in the slave position.
Dec 03, 2008 | Maxtor Hard Drive
Access is denied
Try to scan it with R-Studio or GetDataBack..
Oct 25, 2008 | Samsung (SP0822N) 80 GB Hard Drive
My Toshiba lap top when i try and copy pictures to a disc it will not let me it says D:/is not accessable.incorrect function
I also tried downloading pictures from a cd and it would not read it though it did read a pdf file for documents on another disc
Mar 02, 2008 | Samsung Super-WriteMaster SE-S164L DVD?RW...
first u have format the c:drive the problem is solved
if not u should format all over the system
Feb 20, 2008 | Computers & Internet
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Feb 18, 2008 | Samsung (SP0822N) 80 GB Hard Drive
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
400 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
