Question about Roper REX4634KQ Electric Dryer
Dryer dosnt heat. - Roper REX4634KQ Electric Dryer
  • 4,340 Answers
Check your breaker, turn it FULLY off and back on, and test again. Verify for full air flow outside of the building, the same volume as when the hose is off of the back of the dryer... Air flow restriction will trip thermal limiters, and turn off heat.
Posted on Mar 18, 2011
My tumble dryer dosnt heat up!
check the thermostat and or element.........
cheers
Apr 05, 2015 | Dryers
My dryer has no heat, works but sends dosnt get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 08, 2011 | Dryers
Kenmore dryer dosnt heat up .
heatman101
May 06, 2011 | Dryers
Hi i have a hotpoint tcm condenser dryer and dosnt seem to dry my clothes anymore?
You need to clean all the fluff out of the dryer, the heat exchanger gets fluffed up, the fan gets fluffed up.I am assuming that the dryer is getting hot?
Mar 05, 2011 | Dryers
My dryer dosnt make heat what can be wrong with it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 29, 2010 | Kenmore Dryers
Hi I am having issues wiyh my dryer. I works but dosnt heat
Either your breaker tripped it is the double breaker if one side trips it will run but won't heat, Next it could be one of your thermal cutoffs or you have a bad element. Good luck. I will hope for a tripped breaker.
Aug 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer dosnt heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 13, 2010 | GE DWSR405EBWW Electric Dryer
Heating mode sometime works or not
The most common problem with gas dryers is the ignitor going bad...
Check out this tip that I wrote about that...
heatman101
Apr 04, 2010 | Estate TGDS840JQ Gas Dryer
My dryer has stopped heating i checked the exhaust tube and the lint trap tube(blower tube),was dirty but i still have no heat.also timer dosnt seem to be working on the auto sense dry heat setting, i...
You have a bad thermal fuse and cycling thermostat. You can buy them ina a kit. When the cycling thermostat goes out the dryer cycles on the thermal fuse (High limit) until it goes out causing the dryer to not heat. You can take the back off and look for them. There are two different thermal fuses. One type is round on and looks like other pieces in the back, only smaller around. About the size of a dime. The other is 1/2" wide and 2" long. Both have two wires. You can test and see by unplugging the machine, connecting the two wires going to the piece together. Tape them together so they touch no metal. Now plug machine in and try. DO NOT OPERATE MACHINE WITH PIECE BYPASSED. THIS IS FOR TESTING ONLY.
Please rate solution if helpful.
Aug 26, 2009 | Whirlpool Dryers
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Roper REX4634KQ Electric Dryer Logo
35 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
