Question about LG DLE2532W Electric Dryer
The dryer will turn on but when I push the button to start the drum will not go.
  • LG Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 18, 2011
Baril ne tourne pas
What kind of dryer is this? I assume that this is a front-loading belt-driven drum dryer. What happens if you turn the drum by hand? If it turns freely, it could be that you have a broken belt. If there is some resistence to turning the drum, is it possible to turn the drum while trying to start the dryer (this may require pushing the interlock button and the start button at the same time you turn the drum)? If the dryer starts to work with a little push, the problem is most likely a capacitor on the motor. Otherwise your motor may be work out - worn brushes or bearings.
Apr 07, 2014 | Dryers
Drum not turning
unfortunately your motor is locked up. Try this, with the door open depress the door switch and have some one push the start button while you turn the drum by hand if it starts then you'll know the start winding on the motor is failing
Mar 13, 2012 | Frigidaire GLGR1042FS Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Maytage MDE3080DAYW
Hi, it sounds like you have a bad motor. You can try and open the door, hold the door button while having someone push the start button. Try turning the drum with your hand while these buttons are pushed and see if the dryer starts. It sounds like the start winding has gone bad.
If the drum will not turn, remove the front panel of the dryer and see if something has gotten into the blower wheel to stop it.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 13, 2009 | Maytag MDE308DAYW Electric Dryer
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryer won't turn
The problem is likely a slipping dryer belt. The belt tensioner is not working or the belt needs replacing.
Apr 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
LG DLE2532W Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
