Question about MSI 945GCM5 Motherboard
Jaud1 problem - MSI 945GCM5 Motherboard
JAUD1
download manual from here :
http://www.msi.com/index.php?func=downloadfile&dno=3989&type=manual
see on page 34 :
Front Panel Audio Connector: JAUD1
Note : The odd pins are on one side and the even ones on the other side.
Oct 05, 2009 | MSI K8N Neo4-F Motherboard
MSI motherboard, Front Audio Panel for headphone don't work.
On this motherboard you can enable or disbale the rear panel audio using jumpers on the motherboard. The jumper is labelled JAUD1. I'm assuming that if you select the rear panel, then the front panel will not work. This info is on page 36 of the PDF manual which can download from MSI. Good luck, the link to the manual follows:-
http://www.msi.com/index.php?func=downloadfile&dno=4117&type=manual
Sep 30, 2009 | MSI K8N Neo4-F Motherboard
Ms 6577 ver:4.1 no audio driver
If you don't have front audio panel ,JAUD1 pins # 5&6 and 9&10 have to be jumpered in order to have signal output directed to the rear audio ports,Otherwise the Line Out connector on the back panel will not function.
I hope it solves your problem.
Ed
Jun 14, 2009 | Intel Motherboard
NO Sound - 865PE Neo2-PFS Platinum Edition
You need to install the correct version of the sound drivers from the MSI website under your motherboard type. Third party or from Realtek sound drivers won't make you sound chip works. If after installing sound drivers from MSI website still don't work then your on board sound chip colud be defective.
Jun 29, 2007 | Abit AS8 Motherboard
MSI 945GCM5 Motherboard Logo
87 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
