Print quality my copies come out with about 1/8 inch of one edge black all the way down the sheet. does something need cleaned?
    Problem Solver:
  • 13 Answers
For photocopiers the symptom that you have described could be accounted for by a number of things. The first step would be to determine where the problem is originating from. Dirty optics could be the main culprit. The mirrors used to reflect the image onto the drum unit can build up with dust and cause a darkening of the image or an uneven image darker on one side. Cleaning the optics will correct this. If there are bad or worn seals on the developing unit it may be spilling excess toner down one side of the page as the paper is passing over the transfer corona/roller. You can check for this by stopping the copy process before the paper gets to the fusing assembly. If the dark band is on the paper before it has reached the fuser than it is either the optics, a worn out or possibly over exposed drum or problems with the developing unit or exposure lamps if so equipped. If the copy is clean before it goes through the fusing unit then it could be the fusing rollers have worn out and need to be replaced or if lucky just the fuser cleaning wick, felt or blade is worn and needs to be replaced.
Posted on Aug 04, 2008
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Oct 09, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
The colour not sharp and got vertical line when print
A reason for the non-sharp collorcould be that the ink is not dried correctly, so open the printer settings andclick at the Slow Drying Paper in the Basic tab. Thus, theprinter will let the paper to dry better.
Regarding the vertical line (and not sharp color) we could check the printquality and then align the nozzles:
Checking the print quality: 1. Print a Print Quality Check Sheet.a. Press the Ink or InkManagement key on the control panel of the machine.b. Press the up or down arrow keyto choose Test Print and press OK. c. Press the up or down arrow keyto choose Print Quality and press OK. d. Press Color (Colour) start.The machine begins printing the Print Quality Check Sheet. 2. Closely examine the Print QualityCheck Sheet. Each of the four colors is represented by a slanted square patternmade up of individual blocks. The colors should appear in the following orderfrom left to right: Black - Yellow - Cyan - Magenta. 3. Compare the print quality of theCheck Sheet you just printed with the three examples listed below:
(B) Most of the short diagonal lines are missing from one or more colorblocks
(C)Some parts of the short diagonal lines are missing from one or more colorblocks4. The display will then ask you if theprint quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem. 5. The display will then ask you if theprint quality is OK for Color. Press down the arrow key or 2 or "-" to choose No for color with the problem. 6. The display will then show StartCleaning? Yes No.
Press the up arrow key or 1 or "+" to choose Yes andthe machine will start cleaning the color ink cartridges. 7. When the machine completes cleaningthe print head, press Color(Colour) Start. Another Print Quality CheckSheet will print. 8. Repeat thecleaning and the quality check process following the Step 4-7. 9. Compare thesecond or third Print Quality Check Sheet with the first one you printedin step1:o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you do not see anyimprovement on the second or third Check Sheet, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you see some improvementon the second or third Check Sheet but it's not perfect, repeat thecleaning and the quality check process three more times (totally five times).If you do not see any further improvement after that, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (C) and you do not see any improvement onthe second or third Check Sheet, repeat the cleaning and the quality checkprocess three more times (totally five times). If you stilldo not see any improvement,, please contact Brother Customer Servicefrom "Contact Us".10. Press Stop/Exit.Setting the Alignment:1. Press the Ink or InkManagement key on the control panel. 2. Press the up or down arrow keyto choose Test Print and press OK. 3. Press the up or down arrow keyto choose Alignment and press OK. 4. Press Black (Mono) or Color(Colour) start. The machine begins printing the Alignment CheckSheet. 5. By reviewing this Check Sheet,you can determine if the alignment needs adjustment. 6. Examine the 600 dpi and1200 dpi test prints on the Alignment Check Sheet. If the number 5 sampleof both the 600 dpi and 1200 dpi most closely matches the 0 sample,press the up arrow key or 1 or "+" to choose Yes.
If one of the other samples is a better match for the 0 sample, press the downarrow key or "-" to choose No. The display will thenprompt you to choose the sample that most closely matches the 0 samplefor 600 dpi and then 1200 dpi. 7. Press Stop/Exit.
Aug 04, 2011 | Brother MFC-5860CN InkJet Printer
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
    Do the following to clean the print head:
    1. Press INK key on the control panel.
    2. Press the DOWN arrow key until CLEANING appears on the LCD.
    3. Press OK.
    4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
    5. Press OK.
    The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
    If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
    Do the following to print a Print Quality Check Sheet:
    1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
    2. Press OK. PRINT QUALITY will appear on the LCD.
    3. Press OK.
    4. Press COLOR START.
    NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
    Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
    How do I clean my Brother MFC 210C. I've done it before ont eh computer, but can't find where to do it this time.
    Press the Ink or Ink Management key on the control panel of the machine. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set. Press Color (Colour) Start. The machine begins printing the Print Quality Test Sheet. By reviewing this Test Sheet, you can determine if the print quality needs improvement. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    The display will then show START CLEANING? 1.YES 2. NO. Press 1 (YES) and the machine will start cleaning the color ink cartridges.
    Jan 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
    Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
    Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
    • Print a Print Quality Check Sheet.
      1. ress the Ink or Ink Management key on the control panel of the machine.
      2. Press the up or down arrow key to choose Test Print and press OK.
      3. Press the up or down arrow key to choose Print Quality and press OK.
      4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
    8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
      Press Stop/Exit.
    Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
    Toubleshooting and routine maintainance is what comes oout on myscreen
    Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
    http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
    How to improve print quality Cleaning the print head
    To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
    Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
    Caution
    Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
    1 Press Ink.
    2 Press or to select Cleaning.
    Press Menu/Set.
    3 Press or to select Black, Color or All.
    Press Menu/Set.
    The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
    If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
    1 Press Ink.
    2 Press or to select Test Print.
    Press Menu/Set.
    3 Press or to select Print Quality.
    Press Menu/Set.
    4 Press Color Start.
    The MFC begins printing the Print Quality Check Sheet.
    5 Check the sheet to see if the quality is OK by following these steps:
    Color block quality check
    The LCD shows:
    6 Check the quality of the four color blocks on the sheet.
    7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
    OR
    If you can see missing short lines as shown below, press 2 (No).
    The LCD will ask you if the print quality is OK for black and three colors.
    OK Poor
    Is Quality OK?
    1.Yes 2.No
    Black OK?
    1.Yes 2.N
    8 Press 2 (No) for Black or three colors
    with a problem.
    The LCD shows:
    Press 1 (Yes). The MFC will start cleaning the print head.
    9 After cleaning is finished, press Color Start. The MFC will start
    printing the Print Quality Check Sheet again and then return to
    step 5.
    10 Press Stop/Exit.
    Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
    My copy prints come out blurry after changing ink cartiges
    Try this:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Text printing problem
    maybe your black ink cartridge is empty.....try replacing it... but before you do that try the clean up utility first it might work if its not empty.....
    Feb 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    76 people viewed this question
    jasbo
    jasbo
