Question about Canon Office Equipment & Supplies
Hpw do I replace ink cartridge in printer? - Canon Office Equipment & Supplies
5 Suggested Answers
don_farr
  • 1011 Answers
SOURCE: replaced ink cartridge and printer will now not
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Posted on Dec 10, 2009
  • 39 Answers
SOURCE: Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Posted on Feb 19, 2010
  • 76 Answers
SOURCE: replaced all ink cartridges with
the inks u had replaced might not be the compatible with ur printer you need to change another inks which are compatible only
Posted on Jan 27, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: We have a X5650 Lexmark printer. The ink
    It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
    Posted on Jan 31, 2011
    U162 error on black ink cannon printer
    This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
    If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
    Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
    Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
    How do i remove cartridges before it is expended in epson tx 121
    Replacing an Ink Cartridge Before It Is Expended Using your computer for Windows Using your computer for Mac OS X For best results, use up ink cartridge within six months of opening the package. To replace an ink cartridge before the fon3_72.gif ink light turns on or the status monitor notifies you that the cartridge is expended, follow the instructions in this section. You can replace an ink cartridge using your computer. mark_no.gifNote: Do not open the ink cartridge package until you are ready to install it in the printer. The cartridge is vacuum packed to maintain its reliability. Using your computer for Windows You can view on-screen instructions for replacing an ink cartridge using the printer maintenance utilities. If you need to replace an ink cartridge before it is expended, click the button on the Maintenance tab. cc3440180u.gif For more information on using the printer utilities, see the online help. mark_no.gifNote: If there is a communication problem between the printer and your computer, on-screen instructions for replacing the ink cartridge do not appear. In that case, check all connections and make sure all devices are on. Toplink_top.gif Using your computer for Mac OS X If you need to replace an ink cartridge before it is low or expended, access the Epson Printer Utility 4 dialog box. Accessing the printer driver for Mac OS X cc1895080u.gif For more information on using the printer utilities, see the online help.
    Nov 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
    Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
    To resolve the issue:
    1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
      NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
    2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
      1. Open the printer access door.
        NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
      2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
      3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
      4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
        For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
    3. If the error continues, restart your printer:
      1. Turn off the printer by pressing the power button.
      2. Wait five seconds.
      3. Turn on the printer.
    4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
    5. If the error continues, contact us.
    When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
    1. Locate and select the firmware for your printer.
    2. Follow the instructions to install the firmware.
    Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
    Jun 07, 2011 | Office Equipment & Supplies
    Hpw to reset the inktcatridge
    Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software after downloading the driver from the web sitte.Now connect the Printer which will be detected and installed. Check printer properties to see the ink levels.
    Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
    also be poor ink cartridge contacts
    Mar 17, 2011 | Canon PIXMA MP190 All-In-One InkJet...
    How to replace the ink cartridge
    1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
    2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
    3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    do rate the solution if it helps
    Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
    How do you load new printer cartriges
    To replace an ink cartridge using the fonth.gif ink button, follow the steps below.
    1. Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
    2. Lower the output tray, then open the printer cover.
    3. Press the fonth.gif ink button. The print head moves to the ink cartridge replacement position, the fontp.gif power light begins to flash, and the fonth.gif ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
    4. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it.
    5.Remove the new ink cartridge from its protective bag. Place the ink cartridge vertically into the cartridge holder. Then, push the ink cartridge down until it clicks into place. Do not apply excessive force to the cartridge.
    6. When you are finished replacing the cartridge, close the cartridge cover and the printer cover.
    7. Press the fonth.gif ink button. The printer moves the print head and begins charging the ink delivery system. The fonth.gif ink lights start flashing. This process takes about one minute to complete. When the ink charging process is finished, the printer returns the print head to its home position. The fontp.gif power light will stop flashing and remain on, and the fonth.gif ink out light will turn off. The fontp.gif power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
    Nov 19, 2010 | Epson Office Equipment & Supplies
    Need to change ink catrege help
    Using the printer's control panel In some circumstances, you may need to replace an ink cartridge before it is empty.
    If the fonth.gif ink out light is flashing or is on, replace the empty ink cartridge as described in Replacing an Empty Ink Cartridge.
    To replace an ink cartridge before the fonth.gif ink out light flashes or the Status Monitor notifies you that the cartridge is empty, follow the instructions in this section.
    r_caut.gif Caution: r_space.gif Do not remove the cartridge from the printer until you are ready to replace it with the other one.
    r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
    r_2.gif Lower the output tray, then open the printer cover.
    r_3.gif Press the fonth.gif ink button. The print head will move to the ink cartridge replacement position, and the fontp.gif power light will begin to flash.
    r_space.gif r_note.gif Note: r_space.gif r_space.gif Do not press the fonth.gif ink button over three seconds. Otherwise the printer starts cleaning the print head.
    Jun 13, 2010 | Epson Stylus CX6600 All-In-One InkJet...
    How do I change ink cartridge on my HP inkjet 6500 wireless printer.
    Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
    The methods of replacing the ink cartridge of the printer follows here:
    Open the printer cover
    The printer ink carriage will automatically goes to center
    Once the carriage is in the center, the printer was ready to replace the ink.
    Pull the down slowly the ink tank off the carriage..
    Remember the place where the color/black position.
    Remove each tank one at a time, and replace the ink with a new one.
    Close the printer cover and it now ready to printer.
    HP Deskjet 6500 Series Printer - Setting Definitions
    Hope the instructions provided helps.
    Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
    Install black cartridge, but will not print
    Lets do it this way. Follow these steps again carefully and try to install the Ink.
    Introduction
    Follow the instructions below to replace the ink cartridges.
    Replacing the ink cartridges
    1. Verify that the unit is on.
    2. Open the ink cartridge door.
    3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
    1 - Ink cartridge latch for the black ink cartridge
    2 - Ink cartridge latches for the color ink cartridges
    NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
    4. Pull the ink cartridge toward you out of its slot to remove it.
    5. Remove the new ink cartridge from its packaging.
    6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
    7. Press down on the gray latch until it clicks into place.
    8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
    9. Close the ink cartridge door. Print a test page.
    If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
    Shut down your computer and restart it.
    Re-install the printer driver/software from the start as you did when you bought it.
    Good luck
    Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Hi there
    Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
    Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
    19 people viewed this question
    old marine
    old marine
