Question about Car Audio & Video
I have a Legacy Predator 2000 watt amp with 2 12'' Kicker speakers. It has been in my car for about a year now, and it recently just stopped working. I have the green light to the amp, im not sure about the speakers tho. Me and numerous friends, who have had systems, have tried to see whats wrong. We cannot find anything wrong! We have replaced the cables, took out spliced wires, and everything appears to be ok, can anyone help me?!?!?!
    Sergeant:
    Novelist:
  • 185 Answers
If you have checked your ground, live, remote and RCA's, The problem may lie with your kicker speakers.
There may be a loose wire connection on the speaker terminals (hense no sound).
Check the terminals at the speaker (+) and (-) then check the speaker wires to your amp inputs.
Usually if there is a fault with any wires linked to your amp, the amp goes into protect mode.
If your amp is not going into protect mode, try linking a different speaker to each terminal on your amp (left) then (right). If you get sound through a different speaker, more than likey your speaker wire to your kickers has came loose (due to vibrations) or there is a break in your speaker wire.
Hope this helps. If any more info is needed I'd be happy to help more. Please rate if helpful
Posted on Mar 19, 2011
  • 2 more comments
  • Tasha Mclanaghan
    Tasha Mclanaghan Jan 14, 2014
    no i have a legacy predator amp aswell 2000 watt one and i have the same problem i kno wat i am doing the remote live negative and ground are all as they should be and the ground is goin strait to the chassis sanded down so its a gd conection and using gold plated conectors on the amp and remote EX at first it went into protect mode so i changed the fuse luvly it went to green light power but nothink happens its wired to a 1000 Watt 12" inch jbl and a 500 watt 10 inch
  • Tasha Mclanaghan
    500 watt 10" SUB ZERO and i didnt mean to come acros big headed lol
  • Tasha Mclanaghan
    Add a Commentput that a bit bluntly
  • Tasha Mclanaghan
    i have the same problem im gunna hav to take the amp apart i think and check the inside for bad componants ex
Sub and amp cutout
i guess you need to check the watts of your amp and sub, maybe it not match the power of both item.
Jul 27, 2012 | Legacy Car Audio & Video
I have a 2004 GMC Envoy with a 1000 watt kicker amp with a 2000 watt kicker 15'' L7 and it will dim everything in it, I don't even have to have it really loud what do i do first?
1,what gauge is power wire? Must use 4 ga. minimum 2,what gauge and how long is ground cable? 18 inch maximum 3,battery amps is crucial,check battery fluid level 4,only old school kicker amps are 1 ohm stable,check amp specs
May 14, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Is it safe 2 install these subs 2 a 2000 watt power acustic amp and if so how do I wire them for a 1 ohm stable load
It looks like you have the Power Acoustik OVN1-2000D Mono Block 2000 Watt amp.
Monoblocks all feed speakers normally and cannot be bridged. So hookup your speakers
as normally with + on the amp to + on the speaker and same with the -.
Now for the speakers. I dont know too many Kicker speakers that are 1 ohm but the
monoblock wont care. It will feed the 8,4,2 or 1 ohm speakers the same power. You just may
get less response from the higher ohm speakers-less Bump Bump. You could wire your speakers
in series to get a lower ohm load (2-4ohm speakers in series gives the amp a 2 ohm load) and get
better response. Here is a site that answers many electrical and speaker questions.
See # 57 on the right hand pane. Tells you exactly what will do best. Good luck.
Electronics Answers Made Easy
Apr 27, 2011 | Kicker Car Audio & Video
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 kicker cvr12s and a legacy predator 2400 watt amp and when I turn the radio up the amp goes into protection once they hit a decent time. I just down graded from 15s so I know its not a power...
you prolly have the subs wired to a too low of an ohm load...thats what happend to me. i had the same subs, and a 500.1 watt amp...and they still blew up..whire EACH sub to a 4 ohm...that should work.
Nov 18, 2009 | Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
My L7 won't hit.
unfortunately chances are it is a bad sub. but I would hook it up to someone elses amp and then see if it works. Use same power or less for test. If it dont work then I hope you have a warrenty.
Jan 02, 2009 | Kicker Solo-Baric L7 04S12L74 Car...
2000 watt legacy predator amp
Disconnect all speaker wires from the amplifier's speaker terminals and disconnect the RCA cables from the amp. If the amp still goes into protect, it probably has shorted output transistors.
Feb 17, 2008 | Car Audio & Video
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
