Question about Rainbow E series Canister Wet/Dry Vacuum
My Rainbow E Series poweres on but after a while that it is working it sounds like it wants to power off, the motor seems to loose speed and then it continues.
  • manny112 Mar 21, 2011
    Thxs for the assistance.
  • 5,603 Answers
If you have used it alot, then the brushes are PROBABLY worn and failing. You should take it to have this checked as it will wreck the commutator to run that way requiring whole motor to be replaced. Take it to a repair facility.
Posted on Mar 18, 2011
Vacuum has power but wont run
From your question it sounds like the Rainbow will not run on high speed. Very good chance the Controller Asm 120v e2 Silver Gold is bad. Call us when you are able as we can replace at a discounted price if your machine meets the requirements. Contact Us
RainVac
Sep 07, 2015 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow E2 will run on High speed,but not the low speed.it's as if no power is getting to it,when.you try to switch it on low,but works fine on high
This could be one of two problems. It could be your switch is broken, preventing it from going to low speed. Try clicking it, does it still make a distinctive click sound, does it feel loose? If so it may be your switch: Rainbow e2 power switch
Otherwise if may be your computer in your E2 is starting to go bad. Often times if Rainbow stops going into one of the speeds it is due to a computer going bad. This is an expensive part and repair, so you should probably take it in and make sure it is the computer. Rainbow E2 controller 120v
800-775-6586
GoodVac com
Feb 13, 2015 | Rainbow Vacuums
My rainbow vacuum e series won't turn on.
it could be the switch . or brushes
Feb 01, 2015 | Rainbow Vacuums
Why won't my Rainbow E Series won't turn on?
It sounds like your motor is probably dead.
You would need a new motor if the Rainbow is getting power and the power nozzle works.
You can find a new motor here:
Rainbow motor
GoodVac.com
800-775-6586
Jul 29, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Power nozzle motor not working on my rainbow e2 vacuum?
Check plugin on the power nozzle and poles there may be some thing blocking connections
Dec 28, 2013 | Rainbow E series Canister Wet/Dry Vacuum
How do I get the motor out of the power nozzle on the E-series?
The eSERIES Rainbow has several versions of the power nozzle. Some screw apart and others have snap connections. Look at our website on the manuals page to determine your model. You can also call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Jun 02, 2012 | Rainbow E series Canister Wet/Dry Vacuum
No power
You must have a late model 2006 or newer E2 two speed Rainbow vacuum that has the white foam padding in the canister, to dampen the sound of the motor, and has a red light on the computer board.
I hate to tell you, but your computer is most likely the problem, and is out on your E2 two speed vacuum.
The only solution is to get a new computer for it.
It is realy not worth replacing it, because it may also be the motor. The E2 is a very high tec system, and is not like any other vacuum. When you turn it on, you are not turning on the vacuum. You are turning on the computer, which is controling everything.
I could supply you with another canister, if you are interested.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 20, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
E2 gold series - makes loud noise on start up
That is normal. All E2 two speed Rainbows make that sound. It is because it has a brushless motor that the computer is controling, and the computer is controling everything. The motor rotor has no coils on it on the rotor, which is very small and light, and the computer gives it a small power boost when you first turn on, then increases the power until ir reaches full speed.
Thank you,
Ralph
Jan 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Possable broken/Disconected wire
hope you have checked the obvious first ..the plug are all the conections tight including the fuse? if so check the vac's switch for loose conections .lets face it the mains feeds the switch the switch feeds the motor unless you have a speed switch. sounds like a fault that could be cured with a bit of investigation good luck farr64
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
305 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
