Question about Tomtom ONE XL GPS
My sd card came out of my tom tom, when I put it back in it is not reading the card.
  • 140 Answers
Its cause everything erases when you take out the memory card so put in the memory card in the tom tom and restore your tom tom orr update it and it will work again
Posted on Mar 18, 2011
I put in a sd memory card from my laptob but, it says no card when I tried to record.
you need to make sure that the SD card is compatible with the camcorder. Some camcorders can only read SD cards, and not SDHC cards.
Hope this helps!
Tom
Jul 22, 2011 | Jazz DV151 Camcorder
Device comes on but shows flashing X and nothing else.
The flashing X is usually asscosiated with a corrupt memory card or a pirate copy of a map.
if it is the later then restore the device from a backup to go back to your original map.
If it is a corrupt card then carry on reading below
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now need to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your SD card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the SD card
It should now work
Bob
Aug 05, 2010 | Tomtom ONE XL GPS
A while ago I put a larger sd card in to my unit,as i wanted to install the complete maps of the U.S.A, i PUT A uLTRA 2 GIG CARD IN, IT WORKED FINE, PUT MY GPS AWAY FOR A FEW MONTHS, YESTERDAy i put the...
Most likely you got a hot copy of the maps and it worked fine for a few minutes in the new unit. Check the course of the map because they know if they are purchased new or are being copied. Not saying you did anything wrong just saying the SD card can only be used for one unit. Contact the company and they will set you straight.
Apr 30, 2010 | Tomtom GO GPS Receiver
Display reads problem with map
You now ned to select your tom tom which will also show as a drive.
Then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL 330 GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
I MADE A MISTAKE AND DOMN LOADED A MAPE TWICE AND LOST CONTACT TO
If you backed up your tom tom then restore it from that backup. Two maps should not stop you from getting to the tom tom home web but may stop the home application working properly.
If you have an SD card in remove it and try again if all is good then try put the sd card in a reader rather than the tom tom and make the required deletions from there. Or if you DO have a backup then format the card properly and then restore to it whilst it is in the reader. Then put it back in the tom-tom and you should then be back to where you need
Aug 18, 2009 | Tomtom GO 300 GPS Receiver
When i turn on the tom tom one
I saved the map on to my computer from the tom tom in Tom Tom Home and installed it on to a new SD card and now it working perfectly. I bought a 2mb SD card for £6.70 put it into a card reader and connected to computer and installed map and it gave me the instructions to put into device (Tom Tom) and switch on to connect then off and back into card reader to finish. Then I disconnected device which is important to do by the way put the new Sd card into Tom Tom and it is workink perfectly. I hope this help others who have problems.
May 17, 2009 | Tomtom One Europe v2 GPS Receiver
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
May 05, 2008 | Tomtom One XL GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE XL GPS Logo
129 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
