Question about Whirlpool Dehumidifiers
The dehumidifier is not filling the bucket with water and runs all the time
    Brigadier General:
  • 4,736 Answers
As I told a questioner, yesterday who was having the same problem: The operation a dehumidifier is based on the amount of humidity in the house or room where you have it placed. If the humidity level is low and you have the humidifier set on a low extraction setting, there would be little to no water in the bucket. However, if you have all the settings correct and you still don't get water in the bucket, the top 2 reasons for this are: The Filter needs cleaning and # 2 the drain tube or hole is clogged. The solution for cleaning the filter is a no brainer. The solution for unclogging the drain tube or hole is not that difficult. You will need a 12" to 20" long Plastic Zip Tie (or something similar, but no wire coat hangers), that's small enough to go through the drain tube or hole. When you remove the bucket look up and into the compartment that the bucket came out of and you will see the drain tube or drain hole. Slowly and carefully push the zip tie into the hole and continue to work it into the hole until you reach the curve in the tubing. This is the tricky part. Carefully and gently work it past the curve and about 4" more. Then start removing the Zip Tie as you slowly rotate it. This will dislodge any clogs. As you continue to pull it out, be prepared for water to follow it. If you have water draining out, your problem is solved.
If none of the above solved your problem, the condenser unit may be low on refrigerant. In which case, you will need a pro to service it.
Hope this information helps to solve the problem.
Posted on Mar 18, 2011
Is there a call back on unit lad704tdl dehumidifier
Good Morning Friend,
I understand you are wondering if there is a recall on your Frigidaire dehumidifier, model# LAD704TDL. I see that the bucket is not filling with water when your appliance is running. I don't believe there are any recalls. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction. Hope this is helpful.
-Best regards-
WP
Jun 30, 2014 | Frigidaire Dehumidifier LAD704TDL
The bucket fills up but we have to put a towel down because it leaks all over the floor. What could be wrong ?
Good Afternoon Friend,
I understand that the bucket fills with water and overflows on your Frigidaire dehumidifier, model# FAD704DUD. Please make sure your dehumidifier is installed on a level that will support it with a full bucket of water. If the dehumidifier is moving when it fills with water then this could possibly be the cause of the bucket overflowing. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FAD704DUD 70 Pint Dehumidifier
Motor is making very loud noise when on and bucket is not filling up with water. Machine is getting very very hot at the top when turning on.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Amcor AHD65 Dehumidifier
Dehumidifier will run but the bucket won't fill. Is there a way to run my model without the bucket? I have a maytag m7dh4582a and do not have my manual. Could their be something else wrong with it?
Is it producing water or not??? If no water is being produced, then check out this tip...
If you are making water and it is just going all over the place then, the little spout coming off the bottom of the coil, that runs the water into the bucket is clogged with dirt and you just need to take a small toothpick or knife and work the dirt out of the spout...
heatman101
Jul 23, 2011 | Maytag M7DH45B2A Dehumidifier
My DD50E has stopped collecting water and filling up. It runs but doesn't collect water.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 17, 2011 | DeLonghi DDE50E Dehumidifier
My dehumidifier is running but no water is collecting and the bucket usually fills in a few hours, what can be the trouble I cleaned the screen.
heatman101
Feb 15, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My dehumidifier was running fine then it just stopped filling with water how can I fix this
heatman101
Nov 11, 2010 | LG Goldstar LD65EL Dehumidifier
Can I set my dehumidifier to turn cycle on and off while I am traveling
Normally a dehumidifier will run based on the humidity found in the air in the room it is located in, although many can be set to run all the time.
I don't believe your model can be set to run next Tuesday, Wednesday and Thursday because you will be home and th NOT run next Friday and Saturday because you will be traveling, for example.
Your machine should run on automatic until the bucket fills with water at which time it should stop running until you empty the bucket. Many buckets offer the feature of adding a drain hose you can run to a drain somewhere. Some people have a floor drain they use for such purposes. Others I have known sit the device on the counter and drain into a sink or in the bath tub and drain that way.
For best dehumidifying results, you should run your machine all the time.
I hope I have answered your quesiton. Thanks for considering FixYa.com
Jan 06, 2010 | Frigidaire FDL50R1 Dehumidifier
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on but the bucket never fills up. What is the problem?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 10, 2009 | Kenmore 53509 Dehumidifier
Dehumidifiers Logo
318 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
