Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
My clothes are soaking wet. It is spinning but not enough to sling water out of clothes.
  • Amana Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 18, 2011
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
Not spinning fast enough. Spins, but not as fast as it should, so clothes are still too wet to put in dryer.
I am going to assume this is a top load washer since you didn't specify. There are only a few causes. One would be having too many clothes and it is overloaded causing the clutch to struggle. Or the clutch could be worn out. If there is any water left in the bottom of the tub, then there may be a partial clog in the pump, or hoses somewhere taking too long to pump out the water. The motor may also be weak, but that is usually not the case. Sometimes the top oil seal in the transmission leaks and slings some oil onto the clutch pads making them slip and thus never get up to the proper spin speed.
Take half the clothes out and see if it spins fast enough. If it does, reduce your load size somewhat. If not, read on.
Unplug the machine and disconnect the hoses. Pull it out and tilt it back. Look up underneath to see if there is any signs of oil leaking. If so, the transmission oil seal needs replaced along with the clutch pads. If not, then if you have access to a Wet/dry shop vac, **** the water out of the drain hose. Lay the washer on it's back and remove both hoses from the pump to see if there is anything blocking the water passages. Something small, like a bra wire, can sling over the inner tub and get lodged in the pump inlet. That in itself is not bad but over time lint will collect around it. I have seen all kinds of things choke off the pump including small socks, rug stringies, coins, jewelry chains, etc.
Jan 01, 2010 | Kenmore Washing Machines
My whirlpool washer drains to rinse but when it spins it spins very slow clothes stay soaked
Your machine is not comeing out of the nutrual drain the motor can't tur the tub full of water and wet clothes or it will sling water out and will burn out the motor very quickly so the transmission has a nutrual drain you will need a new transmission sorry
Mar 31, 2009 | Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
209 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
