Question about Dryers
My 800 series elect. dryer doesn't dry the clothes in the set time. The tumbler is turning, the heat is on . Is there a fan ? Thank you Brian
  • 4,341 Answers
Check air flow. yes there is a fan, and if the fan were to not work, then thermal limiters would turn off the heat..
The easy test is to pull off the hose at the back of the machine, and turn it on. Form an opinion of air flow volume. Now hook the hose back up, turn the machine on and go to the discharge port outside of the building. Is the air flow the same? If not, you will have drying problems. Lint builds up and causes problems, eventually. Clean it all out.
Posted on Mar 18, 2011
My bosh next 700 series I not heating to dry the clothes I checked the vent and it not clogged inside and outside. Help pls
Try to reset the thermal cutoff, but should be no reason why it should have tripped.
The actual operating procedure is
The air enters the body of the dryer through the large opening in front of the dryer
Then the air is sucked past the heating element and into the tumbler. (the tumbler is the large bin holding your clothes).
Then after the air has circulated around the clothes, it enters the door and is directed down through the lint screen. (this catches lint from the drying process... some clothes producte more lint (such as towels) than others (such as panties) because the weave is more coarse.
Then the air passes through a duct in the front of the dryer (after the lint filter) and into the fan.
The fan forces the air into the duct leading out the back of the dryer, at which point it exits your house.
It is extremely difficult to tell you the problem without being there to eliminate any one of several things that could be the problem. First, when you have the dryer turned on and have the heat setting set to cottons, is there ANY heat at all? If you feel the door, and there is SOME heat but there is not much heat on the clothes when you feel them, the intake opening in front of the dryer is probably in need of cleaning.
While you should always clean your lint filter after each use of your dryer, you should also periodically clean the intake at least once every six months. If you do not, the air intake is eventually restricted and the drying efficiency of the drye is affected. Consult your owner's manual for the exact location of the air intake.
IF THE INTAKE IS CLEAN and clear of obstruction, and there is still not enough heat to dry the clothes, but the door feels warm when dryer is operating. Then this would imply that the exhaust duct needs cleaned out. This is something that definitely needs done periodically to prevent fire. The exhaust duct collects additional lint that the lint filter misses. While this is a small amount of lint, over a period of time, this builds up on the inside of the exhaust duct and prevents the flow of the exhaust which reduces the heated air flow around the clothes in the tumbler. This results in the air not flowing and not becoming warm enough to dry the clothes efficiently.
IF THERE IS NO HEAT AT ALL: Then there is a likelihood that the heater itself needs replacement. This is a costly repair and you will be wise to invest in another dryer instead.
The working process of your clothes dryer is a relatively simple machine. It brings in air, heats the air, flows the air through the tumber where the clothes tumble loosely with the heated air circulating around them, then the air passes through the lint filter as it exits out your home. The lint filter is necessary because those tiny pieces of fabric (lint) can collect in your exhaust duct and catch fire. This is the major cause of dryer fires. This is why you should also periodically clean out your exhaust duct. Even though you have a lint filter, the lint filter does NOT catch all the lint and lint will eventually coat the interior walls of the exhaust duct.
Apr 20, 2012 | Bosch Dryers
Tip
How a Dryer Works
First, you open the door and place your wet clothes into the tumbler. After you shut the door, you adjust the heat settings. Most dryers have three settings-low, medium, and high heat. Next, you set the timer. It's usually a dial-type timer with various settings. You can set the timer for a specific length of time, like 20 or 80 minutes, or you can let the dryer decide when it's time to turn off. Newer dryers have cycle settings like "optimum dry," "less dry," "fluff," and various others. Some have controls for cotton clothes or permanent press, or other options. Also included is a notification switch, that when set on "loud," sounds a buzzer to let you know the dryer's done. After all the settings are set, you press the "start" button.<br />The motor begins to turn and the belt rotates the tumbler. At the same time, air is drawn into the dryer. Also at the same time, the heating coil flares to life (or the pilot light ignites the heater in a gas dryer) and warms the incoming air. The tumbling clothes heat up and the water within them turns to steam. The exhaust carries the steam out of the dryer, usually through a duct that sends it outside. <br />Sounds simple enough, right? But how does the dryer know not to get too hot, and how does the timer actually work? <br />When you open the control panel on the dryer-which is not recommended unless you know what you're doing, by the way-there will be wires going this way and that. The cycle controller is usually square and has a round device attached to the top of it. The round device is actually a small motor. The motor has a small gear on it that connects to a larger one with a dial inside the cycle controller. As the gear on the motor turns, it turns the dial very slowly. The dial usually has a set of four cams attached to it. As the dial turns, the cams engage certain contacts within the cycle controller. The contacts determine everything that happens, from the length of the drying cycle to whether or not the air gets heated.<br />To ensure your clothes don't go up in flames, dryers have temperature sensors installed in them. They are little silver discs, about the size of a quarter, and there are usually two of them. In most dryers, one is located near the heating coil and the other is in the front section of the dryer. They also have a set of contacts within them, so that when the temperature gets too hot, the contacts separate and the dryer automatically turns off.<br />If you take the top and front of the dryer off (again, not recommended), you will see the exposed tumbler. A belt goes around the tumbler and winds around a pulley that's connected to a motor. There are rubber wheels underneath that sit in a groove in the tumbler to ensure an even and smooth rotation. Depending on the dryer you have, the motor may control the exhaust fan as well.<br />One of the most important factors in how a dryer works is air flow. The dryer has to bring in air to heat in order for everything to work. Most dryers have a hole or ventilation duct located on the front of the machine. It's not visible with the cover on. Air is sucked in through that hole and is forced past the heating element. The heated air flows into the tumbler to heat the clothes. The steam is then sucked out of the dryer through the lint trap and out of the building. The lint trap is usually located right below the door of the dryer. For your dryer to work as efficiently as possible, make sure to clean the lint trap after every load. A fan is used to both bring the air in and send it out. It is located between the lint trap and the ductwork leading outside.<br />For all intents and purposes, the dryer is a very simple machine. It is designed so well that the only thing that really changes over the years is the look of them. But just because they're designed well doesn't mean you'll never have a problem with them. If you are currently having a problem with your dryer, check out our easy repair guide before calling in an appliance repairman. The problem may be an easy one to fix, and you could save yourself a bundle.<span><br /></span>
on Dec 24, 2010 | Dryers
I am renting a house that has an old whirlpool stackable washer/dryer combo. The dryer doesn't heat up very much and it takes 3 hours to dry a small load. Landlord had a tech look at it and found...
Under normal operating conditions, the hot air blown into a clothes dryer's tumbler reaches a temperature of about 175 degrees Celsius.
If its getting hot at all, the problem is with the amount of air that it is dispensing, maybe due to the fan not turning or the duct being plugged up.
Either way there is a problem that needs to be examined.
May 11, 2011 | Dryers
My dryer is giving off outside heat and not drying my clothes
check the filter is clear and the access vent from heater fan to tumbler is not blocked - have seen a sock blocking air flow -
drier is only a fan blowing air over a heated element & through a duct or pipe into the tumbler - on exit the air passes a filter and if this is blocked - through passage is obstructed and hot air will escape backwards
May 26, 2010 | Whirlpool Dryers
Have a kenmore electic dryer just changed out the heating element about 2 months ago dryer is not heating up properly taking 2 times to dry a load of clothes
check for a blockage in the evacuation hose (four inch tubing)
also, check to make sure the blower blades are turning (they can wear out and slip on the motor shaft). assuming the new element is still good, it is probably a blocking of air flow which will inhibit drying properly. or the blower fan blades are broken or worn. good luck. jay
Jan 04, 2010 | Kenmore Dryers
Mayteg model DE313 clothes dryer that stopped drying clothes.
That is a very accurate assessment of the problem. Check the element for continuity between its two contacts. If there is none, replace it. If there is, look for a fuse on the side with two wires going to it. Test it for continuity. If there is none, replace it.
Jul 21, 2009 | Dryers
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Dryer takes 3 times to dry
My tumbler won't turn on my front load Kenmore dryer
Mar 07, 2009 | GE Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Dryers Logo
Top Dryers Experts
