Question about Kenmore Vacuums
Has suction but will not pull particles/pieces/dust into the vaccum
SOURCE: vaccum has no suction
check Belt - if your vacuum has a hose check it for suction --(make and model - canister or upright?) If belt is broken it does not matter how much suction you have - you need aggitation to clean carpet.
Ralph
ifix@shentel.net
Posted on Oct 20, 2007
SOURCE: Wont pick up
Mine was doing this soon after I bought it. I had to cut the strings, and hair off the brush...cleaned the filter (plastic one) and then it seemed to do better. I still have problems with it getting clogged in the tube once in a while...I usually take a broom stick and push it through...I also have a Kirby, I tell ya I am thinking of spending the money to have it fixed because these cheaper ones aren't very good.
Posted on May 05, 2008
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
Posted on May 12, 2008
  • 4088 Answers
SOURCE: Dyson Vaccum suction not strong enough
Look for an obstruction in the air passages at the bottom and where the air enters the canister. Make sure the HEPA filter is not plugged (take it out for a test). Hope this helps!
Posted on Mar 05, 2010
  • 218 Answers
SOURCE: My vaccum motor is running
If every thing is running but you have no suction than there is either a clog in the hose somewhere or the filter is plugged up and needs cleaned out or replaced
Posted on Apr 29, 2011
Testimonial: "Thanks Sid, vacuum hose was clogged. Cheers"
Hi my Dyson dc43 has no suction when using the stick and attachments. It will have suction for about 1 second when I turn on the Vaccum but that's it. It works fine when using the the full function mode....
Hi there my be a blockage at the bottom of the suction pipe. turn the hoover over so its laid flat ,You.ll be able to see were the pipe ends theres a piece plastic which you can press in ,push the clip in and it unclip pull out the plastic unit check for blockages you,ll also be able to see the brush bar.
Nov 02, 2014 | Vacuums
Help my dyson dc fourteen has stopped picking up he brushes dont turn the belt is intact but no suction for bottom of vaccum cleaner the pull out pipe works fine
Most likely your top filter is blocked. You can see it here
http://www.youtube.com/watch?v=l1SvGJAjukY
The most important thing when owning a Dyson is to not overfill the dust container. It will say "max" If you stay under that your filter will stay cleaner longer.
Feb 25, 2014 | Vacuums
Upon turning on vaccum it starts ok, but a second later it spits out some dust dirt out and does not vaccum. We hear like a poof suction when this happens. Cleaned all the tubes around it, but thinking...
The poof suction sound you hear is most likely the suction release valve opening up because there is a clog or restriction somewhere. If you don't feel qualified it is usually a better idea to take it to a qualified repair facility.
Oct 26, 2013 | Panasonic Bagless Upright Vacuum Cleaner ...
My vaccum motor is running brush is rotating it's just it doesn't have suction doesn't **** dust!
Apr 29, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
No suction
try to clean the filter of the vaccuum wash it with water.or dispose the dirt inside maybe your vaccum is full of dust. check the suction hose maybe it clog up or check the rotation of the motor maybe it has reverse rotation try to replace capacitor.
Feb 14, 2011 | Vacuums
I have a shark navigator vacuum that is making a loud noise and sounds like air is blowing out a hole on the side
I found the issue, the square hole in the side is an emergency air release if the suction is not reaching the dust collector. The cylinder filter screen inside the the top of the dust collector had a thick layer of dust which wasn't allowing airflow to the dust collector, hence the air was escaping through the square hole on the side. I cleaned the screen and it worked as if it came right out of the box.
Feb 08, 2011 | Shark Navigator Bagless Upright Vacuum
Mar 05, 2010 | Vacuums
My hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Aug 25, 2008 | Hoover S3614 Vacuum
Vacuum
I just discovered that if you remove the dust cup, lay the vaccum back, reach up inside above the dust cup area, there is a yellow piece that can be removed (twist it and it comes out.) I found that there were GOBS of lint and pet hair stuck inside there. We removed all of that and the vacuum works great again!
Jul 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vaccum has no suction
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Vacuums Logo
232 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
