Question about American Standard Plumbing
How do I replace the thermostat cartridge on the AS 2050.200 shower body
The grey cartridge (diverter valve) of my shower is discontinued. The whole copper piece costs over $100. The piece I need only costs about $20. Any suggestions if I can find this anywhere else?
Replace Shower valve - how much $? - RedFlagDeals.com Forums
forums.redflagdeals.com > Home & Garden
Nov 27, 2011 - Hi all Just bought a new shower column from Rona. ... the valving is in the pressure balance valve, thermostatic valve, diverter valve or volume ...
How To Troubleshoot A Thermostatic Shower Valve ...
? 9:45
https://www.youtube.com/watch?v=2pVuvG6q84A
Aug 10, 2011 - Uploaded by bathstore
This video shows you how to troubleshoot and rectify thermostatic control problems and the on/off control for a ...
Shower Systems & Valves - Home Depot
Jan 01, 2016 | Home
There is no hot water
Hi Marshall,
Do you mean that no hot water is reaching the shower, or do you mean that no hot water is coming out of the shower. The answer to this will determine where the problem is.
If no hot water is reaching your shower, then there is probably a problem with the boiler or the pipe is blocked. You can easily test this. You can turn on other faucets in the bathroom to check whether any hot water is reaching those.
If the problem isn't with the boiler and the shower is in fact receiving hot water, then the problem will be with the shower mixer valve, specifically the thermostatic cartridge. The cartridge controls water temperature. The inner workings of the cartridge move up and down to adjust the amount of hot and cold water entering the cartridge. If it has seized up, the moving part can get stuck in a certain position. It sounds like this could be the case with you and therefore replacing the cartridge should in theory fix the problem.
Hope this helps. Shower Thermostatic Cartridge Spares
Nov 14, 2015 | Home
Flow rate on delta thermostatic valve
the two screws are service stops open them all the way
Jun 09, 2012 | Delta & Single Handle Shower Faucet
We replaced the cartridge of our one handle shower faucet and now the spigot leaks a steady stream of water
wrong stem.. the body of cartridge where the o ring seats into the body of the faucet needs to go all the way down.. try looking at new ong very carefully because they are almost identical except for this
Sep 02, 2010 | Danco Faucet Cartridge
The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Oct 11, 2009 | Delta & Single Handle Shower Faucet
Plumbing Logo
61 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
