Question about kawasaki 5-DVD Home Theater System - 1152 System
How do I get the tv to run volume(sound) to come through my Kawasaki home theatre system
    Brigadier General:
  • 8,546 Answers
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical or HDMI cable is expensive). You COULD skip the TV entirely. Many don
Posted on Mar 18, 2011
Sony BDVE870 Low Volume
use equalizer to increase volume
May 19, 2012 | Sony Audio Players & Recorders
Poor sound quality
A new LCD TV has expansion sound capabilities requiring adjustment to acheive viewer experience. First, the TVs default sound is what is heard soon as the powered on. Tempering with the remote controls volume fucntionalities to achieve adjustment suitable. The volume feature on the remote produces adjustment either reduceable or increasing sound magniftude. Hower, the LCD TV is capable of producing extensive qualility sound with separate devices that generate sound. For example, acquring an external speaker system mentionable as home theatre system has already build blusting capabilities requirements. Once an external home theater sould producer devices are connected to the LCD TV, the expansion capability is increased. For example, the home theatre devices have woofers as bass magnifiers, tweeters as sound impression magnififers, and additionally, speakers with magnifier capacities. The LCD TV is designed to accomodate any extenal devices only mentionable example as the home theater sound sytems acquirable at retail. LCD TV sound capacities are capable of being modulated by using the remote control to access the settings areas on which sound is alteratered. Consult the LCD TV user guide for additional details on manipulating audio sound functionalities.
goodluck
Jan 08, 2011 | Vizio M370VT 37 in. LCD TV
I have an old JCX TS750 Home theatre system.Is it possible to put the tv sound into the speakers. many thanks ...
Yes. Connect the audio from the cable box to the home theatre. Just change your function when u are watching tv to video 2 or where ever u plugged it in. Then turn your tv volume down and use volume on this sanyo
Jan 06, 2011 | Sanyo Televison & Video
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the...
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Aug 15, 2010 | Panasonic Audio Players & Recorders
TV Hookup
The TV is NOT a source of high quality sound.
For the best serious audio I would recommend drawing the audio-only digital feed from the Cable Box via its highest quality audio output. Then turn the TV's volume down. Also run the vanilla RCA stereo audio pair from the cable box to the TV in case you just want to check the weather.
Mar 05, 2010 | Koss C220 System
LG LHB953 Theatre system volume control with comcast dvr 3
Try the help menu in the comcast remote. I believe you have to program it again for the LG to work the sound.
Jan 01, 2010 | Televison & Video
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
121 people viewed this question
Top kawasaki Audio Players & Recorders Experts
Gareth Cockram
Gareth Cockram
Are you a kawasaki Audio Player and Recorder Expert? Answer questions, earn points and help others
