Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
When my Sylvania 28' is off it makes a slow clicking noise until I shake or move the TV. The noise will continue all night if undisturbed.
Im hearing a clicking noise when I brake
Is it just one click or continuous slowing down clicking? In first case it's brakes support fix issue, on the second - something has been cought up between the pad and disc. You can try to check it on your own but better have it serviced at the shop.
Mar 02, 2015 | Sylvania Osram Diadem Py21w 581 Indicator...
Clicking noise
water going through heater too slow pump impeller might have restriction manual bypass spring in header might be defective check to see if filters are clean
May 03, 2013 | Jandy Pool & Spa
My TV keeps switching its self off, it makes a clicking noise as if its trying to switch on. Then cuts out.
Do to the clicking noise your tv makes is a very common idicator that your power supply in the tv is failing. Its an easy fix lots of DIY videos on youtube but may cost you a arm.
Apr 29, 2013 | Philips 28PW6506 28" TV
There is a continual clicking sound when in motion
If it is in the dash it is the AC/Heater automatic air temperature control blend door actuator that is makeing noise due to a jammed/warped or slow moving blend door.
Oct 10, 2012 | 2004 Chevrolet Silverado 2500HD
Pictures are blurry
There are a few things to consider:
-- Are your hands steady as you take the shot, and are you moving the camera before the shutter actually clicks? As a test, put the camera down on a table top and take a picture without moving the camera until well after the shutter clicks. If the resulting image is not blurry--you just proved that your holding technique needs improvement!
--This camera has image stabilization to help you deal with camera shake--do you have this feature turned on in the menu?
--If your subjects are moving and your shutter speed is slow (meaning that the shutter stays open a relatively long time to gather enough light) then you will get blur. And, even if your subject is not moving but the shutter speed is slow, then your camera shake will come back to haunt you.
To fix slow shutter speed, you can either use a flash to freeze the action, or you can manually increase the ISO setting to a higher number, or you can choose a preset like "sports" which will tell the camera you want faster shutter speeds. A higher ISO setting will allow for faster shutter speeds, but it can also result in a grainy look, called "noise" if you set it too high.
Most likely it is your holding technique and the setting you are choosing that is causing the blur. If you are in decently bright light outdoors, you hold your camera steady and wait for the shutter to click, and you have image stabilization on, then you should have sharp pictures. If you are indoors, expect to need a flash.
Nov 25, 2010 | Canon PowerShot SX100 IS Digital Camera
Will not turn on or off, just makes clicking noise
Remove back cover and check uF 10V caps for swelling and or leakage. If some of them are swollen replace all 10 volt caps with 3300uF 16V. There are about 10 one is 1000uF.
Apr 14, 2010 | LG 42PX5D 42 in. Plasma HDTV
Watch was running fine (auto) stopped in middle of night-can shake- second hand does not move
Unscrew the crown and pull out gentle until it clicks outwards twice as if you were going to reset the time and then push it back in and try shaking gently to start the second hand
Jan 23, 2010 | Tag Heuer Watches
Front end and steering wheel shakes
when slowing to make right turn is it more like a clicking noise, does it do it while turning or just when slowing down. If it is while you are turning it is most likely the right cv axle drive shaft popping. When at a stop with ac on does it shake if you put it in park and how do the rpms read in park or in drive. Did they change the trans mount also dont thank that is it just trying to get a better understanding so I can better assist you.
Jul 16, 2009 | 2002 Ford ZX2
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
TV Turned off, now there is a clicking noise when plugged in.
had a 51" GE rear projection donated to myself. While off and power button pressed there was a clicking noise from the front of the unit. Rear cover was removed and it could be observed that the hv splitter had a crack in the casing and the power was arcing out of the splitter. I purchased a $72 dollar hv splitter, i read that the $20-$30 dollar one would break within a year, and the unit powered up no problems.
Nov 20, 2005 | GE 46GW947 46" Rear Projection Television
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
21 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
