Question about GE Dryers
DRSR483GD2WW runs but has no heat. Vent was cloged. removed clog. Looked under dryer to see if ignighter? was working. saw no glow
  • 958 Answers
It could have overheated already due to a clogged vent and has tripped off the high heat limit switch which once open, will need to be replaced.
please check you wiring diagram for its location, it could be tested with an ordinary vom meter. it should have continuity.
cheers,
drcool
Posted on Aug 02, 2008
Kenmore 700 series dryer problems
This could be a few things. The first thing to check is your dryers vent, make sure its not clogged and check were it exits the house because sometimes nest are made in them. A clogged vent will prevent proper drying because the moisture can not escape and/or the heating element turns off due to overheating.
If the vent is clear, with dryer empty open the door and hold down the door switch (button that tells dryer door is closed) and turn on dryer, as its running watch the back area of drum were the vent with little holes is, within a few seconds you should start to see an orange glow in that area. If the orange glow starts then disappears within a few seconds it means your vent is clogged, if there is no orange glow at all then you have either a bad heating coil or bad high limit switches. I believe youtube has great how to videos on how to replace them, its not that hard if you have basic repair skills. Hope this helps you and your able to get it drying agian
Dec 23, 2013 | Dryers
Sears dryer back left vent has an orange glow form heating element is this normal bought in May of 2012
Yes, this is normal for the element to glow orange like this. It's getting full 240 volts and good heating.
Dec 01, 2012 | Dryers
No heat/ heating element needs replacement!! How do u replace!! I looked at a video, but the dryer i saw wasnt like mine!!
Is it possible the dryer vent that runs from the dryer to the outside of the house is clogged with lint. This happens to us. Just thought I would suggest this, in case you weren't sure if it was the heating element or not. Good luck!
Apr 14, 2011 | Amana Dryers
Will start, won't completely dry our clothes... Taking FOEVER!!!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 01, 2011 | Dryers
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer doesn't dry, lint not cloged, gas ignights
When you say lint not clogged I assume you mean the removable lint trap in the dryer. If the drum gets hot (open the door a few minutes into the cycle) then most likely you have a vent problem. You will need to check if the vent is blocked solid either by lint or if the vent pipe is crushed. I would suggest going out to whereever the vent ends on the outside of the building and see if air is getting blown out with the dryer on. If no air is coming out then chances are it is blocked. If the drum is cold then gas flame is not getting hot.
May 12, 2009 | Kenmore 72062 Gas Dryer
My frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Mar 15, 2009 | Dryers
Hot air coming in but not drying Model LE6800XTWO
Sounds like you have a clod inside your dryer that may be preventing the blower fan from cycling air properly. When was the last time you inspected the dryer vent and/or inside the dryer for lint? The symptom sounds like you could have a couple of possible issues. The dryer may have restricted air flow (Meaning, the vent hose is clogged from where it leaves the dryer to the vent outside. Or...the dryer may be clogged inside the air baffle inside the dryer where the lint screen goes.) You may also have a high limit thermostat that is malfunctioning or a blower fan not working properly. Here's some recommendations:
1. Remove the dryer vent hose from the dryer and turn the dryer on. Is the air leaving the dryer forceful and warm? (The air should measure about 140 degrees F) If so...you probably have a clog or kink in the ducting somewhere between the dryer and where it exits the house. If the air is weak and cool, you will need to inspect your dryer interior to find what is obstructing the air flow. Rodents are notorious for building nests inside the vent line or air baffle. Check the air blower fan to see if it is rotating. If enough lint is allowed to build up, it can obstruct the rotation of the blower fan. It some cases, the fan can shear off on the motor shaft and must be replaced.
2. Can you access the heating element so you can see it? Start the dryer with the casing removed so you can watch the heating element. The element should glow red, but not so bright that it glows like the sun, and it should cycle on and off. If it glows continuously, the high limit thermostat is a likely suspect and should be replaced. (NOTE: It is recommended that you replace the high limit thermostat and thermal cut-out at the same time. Some manufacturers will sell the two as a pair).
HINTS: If you have a lint screen in the door, you should be able to access the heating element by removing a panel under the door. If your lint screen is on top of the washer, you will have to remove the rear panel of the dryer to see the heating element.
If the dryer is left to run in an overheated or clogged condition, the thermal cut-out and/or heating element will eventually blow. It is recommended that you inspect the dryer to see what is causing your current problem. You should inspect the dryer ducting and exhaust about once per season and keep it cleaned. Clogged dryers are a hazard and can contribute to house fires.
CAUTION: Always unplug the dryer if you are servicing the inside of the unit. Dangerous voltages are present even with the unit turned off. Also, unplug the dryer if you have to remove the rear panel. The 220VAC terminal is directly behind the panel and can cause electric shock if touched.
I hope this information helps you and post back if you need any further assistance.
PS Improper sorting of laundry can also attribute to longer dry times. Try not to dry dense or heavy items (i.e., towels and jeans) with lighter items like cottons and linens. More dense material holds moisture longer and can transfer this moisture to other articles you are attempting to dry.
May 23, 2008 | Whirlpool LER5636P Electric Dryer
Oven not working but burners are...
replace the glowbar just because it glowes doesnt mean its good the one you want to replace is the bottom one take the racks out and remove the bottom panel there are two screws remove the then under that will be a flame spreader remove that under that will be the burner bar and ignighter
May 22, 2008 | Frigidaire TGF317 Gas Kitchen Range
Whirlpool ultimate care gas dryer
the glow bar on the gas ignighter
Mar 15, 2008 | Dryers
Dryers Logo
138 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
