Question about Xerox Phaser 6130 Laser Printer
Panel says: insert yellow cartridge after replacing with a new one, it's still there. tried unplugging the printer and waiting before turning it back on. still same error message
  • 167 Answers
SOURCE: No Cartridge error message on Xerox PE120i
The cartridge's sensing is bad or either the cartridge is refilled one (then u need to replace the crum)
omnipresent
Posted on Nov 04, 2007
printech
  • 159 Answers
SOURCE: HP Photosmart 3310 all in way Error Ink System had Failed 0xc18a0101
what's kind of error ?
Posted on Apr 05, 2008
  • 16 Answers
SOURCE: Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Posted on Apr 29, 2008
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
pdouglasss
  • 125 Answers
SOURCE: I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
Posted on May 24, 2009
I have an HP Photosmart A526 printer. I have tried 2 new cartridges and neither print yellow. I thought it was a fault with the cartridges but now think it may be the printer. I have aligned and...
There are two possible malfunctioning in this case.
  • Issue with the cartridge.
  • Issue with the printer.
Its better if we start resolving this issue linearly and logically first by following these steps as given in the manual on the following link.
Please click here:
Missing, Faded, or Dull ColorsIf the above doesn't help, we might try a printer reset to bring it back to the default print settings and configuration.
Performing a Partial Reset
  1. Disconnect any universal serial bus (USB) cables attached to the printer.
  2. Open the print cartridge door and remove the print cartridge.
  3. Close the print cartridge door
  4. Press the Power button to turn the printer off and wait for the printer to shut down before proceeding to the next step.
  5. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  • Wait approximately fifteen to forty-five seconds and proceed to the next step.
  • Plug the AC adapter back into the wall outlet, and then into the printer, but do not plug in the USB cable.
  • Wait for the appropriate missing print cartridge error to verify that the printer can recognize this error.
  • Open the print cartridge door and re-insert the ink cartridge.
  • Print an internal test page.
    1. Remove any memory card, if inserted.
    2. Use the arrows (c01070297.jpg ) to highlight Print test page .
    3. Press Print to begin printing a test page.
    This is how the Test Page looks like:
    If still the printer is not printing the way it should, we might think of going for a HARD RESET by following the steps below:
    Performing a hard reset of the printer
    1. Unplug the power cable from the back of the product.
    2. Unplug the power cable from the electrical outlet.
    3. Wait 15 seconds.
    4. Reconnect the power cable into the product and then reconnect the power cable into the electrical outlet.
    5. If the product does not turn on, press the On button.
    This should bring the printer back to normal.
    Wish you luck.
    Regards,
    techbuddy247
    Nov 15, 2010 | HP Photosmart A526 photo printer
    0xc18a0406
    Hi there
    Try the following steps to remove HP Printer Error Code 0xc18a0001.
    I have put 3 ways for you to try.
    1. Without turning off the printer, unplug the USB cable.
    2. Remove the cartridges.
    3. Wait until the message "Insert cartridge" appears.
    4. Unplug the power cord.
    5. Wait 60 seconds.
    6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
    7. Reinsert the cartridges and close the lid.
    8. If the printer has a page of calibration accept.
    9. Reconnect the USB cable and remake an impression.
    10. If the problem persists, the machine must be repaired.
    Or try 2
    Turn the printer and wait until you receive the error message.
    * Simultaneously press the keys "9" and "#" printer.
    * While holding the button down, unplug the power cord from the unit.
    * Wait a few seconds.
    * Still holding the button down, reconnect the cable and turn on the printer.
    * Release the buttons.
    Or try 3
    * Turn the printer and wait until you receive the error message.
    Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    Apr 26, 2010 | HP Photosmart 3210 Printer
    I have replaced my yellow cartridge two times now on my hp C5180 printer. I keep getting the message that I need to replace the yellow cartridge. Can you help me?
    Try this: Remove all cartridges, then turn of printer and unplug it.Wait 10 min and plug it again.Turn on it and wait to ask the cartridges then put it one by one.Hope it help.
    Nov 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
    HP 3210 Printer Error Message :0xc18a0306
    Reset the product:
    1. Without turning off the product, disconnect the USB cable from the rear of the product.
    2. Remove the cartridges from the product.
    3. Wait for the 'Insert Cartridges ' message to display on the control panel.
    4. Disconnect the power cord from the back of the product.
    5. Wait 60 seconds.
    6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
    7. Reinsert the cartridges, and then close any open doors on the product.
    8. If you receive a prompt to print a calibration page, do so.
    9. Reconnect the USB cable to the rear of the product, and then try printing again.
    Jul 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
    HELP ON MFC-240C
    IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
    Press the On button to turn the printer off.
    Unplug the power cord from the back of the printer.
    Remove all the ink cartridges.
    Wait two minutes.
    Plug the power cord into the back of the printer.
    Press the On button to turn the printer on.
    Install the ink cartridges when prompted.
    If the error code does not display, the issue is resolved.
    If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
    Sep 01, 2008 | Brother MFC 240C All-In-One InkJet Printer
    Install cartridge
    I have the same problem with my magenta. I've installed a new cartridge and it just keeps telling me it's out. For awhile it was allowing me to print in black only, but now it just won't do anything. HELP!
    Aug 02, 2008 | HP Photosmart C5180 All-In-One InkJet...
    Operating problem as described below
    unplug mfc from power outlet. take all carts out and leave scanner open. wait a minute. replug to power. wait until machine demands carts. insert one after another and ANSWER display! Close cover.
    NEVER change cart until mfc stopps printing (near empty is a reminder to buy new ones :-))
    Jun 18, 2008 | Brother MFC 420CN All-In-One InkJet...
    Replacement of ink cartridges
    1. Press the On button to turn the printer off.
    2. Unplug the power cord from the back of the printer.
    3. Remove all the ink cartridges.
    4. Wait two minutes.
    5. Plug the power cord into the back of the printer.
    6. Press the On button to turn the printer on.
    7. Install the ink cartridges when prompted.
    Jan 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
    Xerox Phaser 6130 Laser Printer Logo
    113 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
