Question about Dishwashers
Hobart model # C44 old dishwasher, wash pump motor will not remove impeller will not clear the hole, how to remove the impeller?
SOURCE: maytag dishwasher mdb9600awb - loud pump
This has happened a few times to me as well.(VERY VERY LOUD NOISE AT THE BOTTOM)I have the same model It did stop.I did a little reading and came to the conclusion that it was the built in food disposer chopping blades were chopping up something like a cherry pit or peach pit and once an end of a wooden spoon that dropped down.If you look at your USE and care Guide on page 12 under trouble shooting "Dishwasher seems noisy"..I went through the same thing taking things apart.Its got to be it. Mine is 2 1/2 years as well. Hope this helps. ronkeachie@rogers.com
Posted on Oct 06, 2007
bigg t
  • 640 Answers
SOURCE: Pump Continuously surges
hi,im a hobart service tech.couple of things to try (you may already have)--check the wash arms at the seams make sure their not cracked,make sure the drain is sealed and not leaking at all.if the unit loses any water or the wash arms are cracked at the seam the unit will sound like its starving for water.make sure the unit is leveled.next time you go back if its acting up pour a half gallon of water in the tank and see if it runs correctly,if it does you could be losing water or the water fill vave could be acting up and not letting enough water in.let me know.
Posted on Jan 13, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore ultra wash dishwasher model number 665.158.5090
the only way you can tell if the upper rack is not getting enough water is to turn a glass right side up in each corner. then run for 2 minutes and see if there is water in each cup.
if you still dont get water, then you have checked the pump, the only thing left is that you are not getting enough water into the unit.
start the d/w at a normal cycle, let it fill and go into the wash cycle, takes about 3 minutes, then check to see if the water level is just below the heating element. if so then it has to be the wash pump being plugged.
if not enough water then you should change the water inlet valve. some times they do get plugged but also make sure you are getting full water pressure to the unit as that could cause not enough water into unit. the faucet under sink could be at fault i have seen valve work but not let enough water in, so dont be surprised if you need a new valve.
Posted on Jan 06, 2009
SOURCE: Frigidaire dishwasher impeller melted! Can't find replacement part!
I have the same problem and after talking to a local service center and doing some online research (remember: Google is your friend) I have discovered this is considered a non-serviceable part and you must buy the entire motor. The impeller comes with the motor. This is probably not the answer you were hoping but is what you have to do. With that said, I plan to JB Weld the ****** back on the motor shaft!
Posted on Feb 11, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: HOBART FX-20 dishwasher out of order
There is one glued to the lower panel on the inside. Hobart is very tight lip'd when it comes to getting any info from their web site. Best I can do, sorry.
Posted on Jan 25, 2010
I have a Hobart am 14 with a new pump motor drawing high amps
Search Results
    Dishwasher Electrical Problems - Chapter 6 - Dishwasher ...
    www.appliancerepair.net/dishwasher-repair-6.html
    If the dishwasher is loaded with a lot of food residue, it will need extra rinse cycles .....changes, they will be explained in instructions that come with the new timer. ... If you have an ammeter, the stalled motor will be drawing 10 to 20 amps or more. ... Since the resistance of the heater is very high compared to the resistance of ...
    Pump Repair FAQ - OTP Industrial Solutions
Nov 26, 2015 | Hobart Dishwasher Am-14 Commercial Dish...
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart Dishwashers
Hobart LXiH error E4 AND a part makes noise when off
test this steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
It is hobart kdi-21a. I got the water out but looks like it is garbage in the bottom. Big screen open but maybe down in the pump? Can I remove the lower X wash arm, no screw but a big rivet?
You can lift off the wash arm and pump screen. You will see the pump shell with screws to separate the top from the bottom. Next is the wash impeller with a center screw and a drive washer. Under the impeller are shims. Don't loose any. The same with under the drain impeller. Just be methodical with your disassembly, lay the parts out in a row as you remove them, and reassemble in reverse order once you have cleared the problem.
Sep 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher won't drain?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Jun 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Model # TKM-27 Institutional dishwasher
Does the motor hum?Did you try to press the overload button on the motor?
Nov 06, 2008 | Hobart 41 in. AM14-255 Free-standing...
Dishwashers Logo
160 people viewed this question
Top Dishwashers Experts
Owen Barnes
