When connected to stereo, the sound is distorted,,
    Scholar:
  • 79 Answers
Hello, this problem can be solved by lowering the sound output to your stereo in the small speaker icon in the windows taskbar, play some music anl then left-click the speaker icon, lower the volume to suit your needs. have a nice day buddy...
Posted on Mar 18, 2011
Kenwood kax-38 amp. distorted sound from turnatable if connected to the phono rca plugs, but ok if connected to the CD rca plugs.
The phono sockets for this are at different line levels for that reason. Phone is for the turntable depending on the type. If it is a later model stereo and an older model cheaper turntable, it uses an older type of needle cartridge called ceramic. The signal output of it is higher than the later magnetic cartridges and may need a preamp (radio shack) to match the line level signal, allowing it to clear the distortion. If this scenario were reversed, using an older cheaper stereo with a later, better quality turntable, the opposite would happen. (signal to low) This preamp would amplify the input. I think you need what is called a matcher to lower the input signal instead of the preamp. I've seen these at radioshack. BTW, the CD input doesn't distort as much because a cd player puts out a high signal and the amp is matched to accept it.
Dec 03, 2013 | SR-10 Adpater Cable - Kenwood Twin-Pin...
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
Sound distortion on medium volume with radio, cd, aux, ect.
The problem is in the audio driver or output stage which is normally an ic semiconductor, it is recommended that a technician look at the stereo to assess cost.
Sep 24, 2012 | Philips FWC527 CD Shelf System
I bought a system and this scosche fa1-3a came with it and I have no idea what its for please help
This device is used to connect the speakers out puts to an amplifier.
Usually a car stereo speakers are high volume out puts and it can damage the sound (distortion) at the time to connect an amplifier so the best way with less distortion is hooking up this device to low the volume and get a clean sound to be amplified
Dec 03, 2010 | Scosche Industries Scosche Slc4 Speaker...
I like the sound of my practise amp but it's not powerful enough can i connect it to a larger amp without getting feedback/distortion?
you can use the record outputs to run the signal into a stereo receiver without problems, though it would likely sound better with a shure sm57 microphone hooked up to a mixing board or other instrument amp.
the record output should be PERFECTLY balanced to hook up to a consumer-level stereo reciever with NO distortion; however, this record output might be too loud for another instrument amplifier or a mixing board; hence, the microphone in the latter situation.
short answer- "yes, but..."
Nov 26, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
Playing MP3 Via AUX comes out crackly
Try turning the volume lowwer on the mp3 player and higher on the head unit. The radio is trying to amplify an amplified sound which is why you are getting distortion.
Mar 22, 2010 | Car Audio & Video
Sound Distortion on Mlt1912
The hard way, if you have the skill, is to replace the speakers.  The bad news is that this probable won't fix it as it is likely that it is internal noise causing the distortion.
there is an easy solution that will probable work.  Using the audio output connection you could hook it up to a stereo system or boom box and use those for sound.   the only thing technical is making sute your cord has the right connectors/adapters on each end.  take a picutre or a good look at both devices audio connectors (output on the TV, input on the Stereo/boombox) and the salesman at your local electronics store should be able to help you find just what you need.
at a guess you will likely need an RCA female to RCA female cord or an RCA to stereo mini male.
hope this helps.
Long_Knight
Sep 02, 2008 | Memorex Televison & Video
Not transmitting through both speakers properly
The UTX-B1 input is not a stereo jack, and the receiver output is also not a stereo jack. Only the receiver Headphone/Monitor jack is stereo.
Not sure if you are sending stereo signals from or to the camcorder. But you can try mono-to-stereo adapter.
Hope it helps!
Jul 16, 2008 | Sony (UWP-S1) Professional Microphone
Distorted sound.
Your turntable is a preamp. Your amplifier might be going bad. did you connect it into phono? dont connect it into the cd or dvd input because those wont work.
May 11, 2008 | Technics SL-1200MK5 Turntable
Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Dec 17, 2007 | Onkyo TX-SR500 Receiver
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
