Question about Kenmore Dryers
Dryer turns off immediatly after starting. - Kenmore Dryers
  • 43 Answers
TERMOSTATUL INTRERUPE DIN CAUZA SCURT REZISTENTA SAU NU PORNESTE VENTILATOR.
Posted on Mar 18, 2011
Is oil light suppose to come on before starting bike just changed oil and filter theres 3 holes in window for oil
When You Turn The Switch To The On Position. The Oil Light Should Be On This Basicly Shows That Bulb Is Good. When Engine Starts And Is Running The Light Should Go Out Immediatly Indicating Oil Pressure.If The Light Does Not Go Out Shut Engine Off Immediatly And Investigate.OIL Level , SENDING UNIT, Loose Wire At SENDING UNIT.
Mar 17, 2013 | 1995 kawasaki GPZ 1100
Dryer hums and heats when plugged in
What is the complete model number of your unit?
Dec 02, 2012 | Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
I JUST INSTALLED A MAYTAG STACKABLE WASHER AND DRYER AND WHEN I TURNED THE WATER SUPPLY ON THE WATER STARTED TO FILL UP IN THE WASHER IMMEDIATLY AND IT WONT STOP UNTIL I TURN OFF THE WATER SUPPLY TO THE...
Unplug the washer, if the issue continues, you have a faulty inlet water valve. What happens is particulate matter gets in and the valve jambs. If you have a new unit, the repair should be for free.
The only case where I could see water going in, is if it was requested, by user input....But front loaders use tons less water......
Feb 12, 2011 | Maytag LSE7806A Top Load Stacked...
I have a Miele dryer, model T494C. The system starts rotate right then stops and when rotates left and immediatly the main relay of the house falls. After three days the dryer works fine. Is there...
It's most likely one of the heat/humidity sensor tubes that needs to be replaced. This has happened twice to my T494C in 12 years. Miele (or your dealer) will come out and replace it for a cost. Do NOT leave wet clothes (or semi-dry clothes) in the dryer for any length of time when the dryer is not operating. Apparently this is one of the problems.
Nov 23, 2009 | Miele Dryers
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
