Question about Echo Garden
My Echo GT 2000 starts and runs great but after using it for 5 minutes it shuts off. I have to wait about 10 minutes before I can get it started again. It does the same thing over and over. What seems to be the problem?
  • 159 Answers
SOURCE: shuts off after turning on
Try changing out the batteries or charging the camera,also with a digital camera they will kill ordinary alkaline batteries I suggest using e titanium
Posted on Dec 25, 2008
  • 8 Answers
SOURCE: lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
dennymulford
  • 1055 Answers
SOURCE: 2000 Grand am gt 3.4 dies out when driving
no its vapor locking losen up the fuel cap and leave it lose your vent line is prob plugged
Posted on Mar 04, 2009
  • 10865 Answers
SOURCE: tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Posted on Apr 24, 2009
  • 10865 Answers
SOURCE: craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
Posted on May 20, 2009
2000 gmc c6500 wont start
We have a 2000 GMC 6500 454 engine. Truck will shut off, we turn off the the ignition wait for about 4 or 5 minutes. Doing waiting time, if you turn the ignition part way on, you can't hear the fuel pump, and if you try to start, it will not start . But after the 4 or 5 minutes, when you turn the ignition part way on, you hear the fuel pump, then it will start. It will shut down with a heavy load or even with out any load. It seems to do it more often when it's really hot out. It will shut down as much as 10 times.
Sep 05, 2013 | GMC C3500 Cars & Trucks
How to rekey a pontiac sunfire 2004
Im assuming you are refering to the anti theft security key relearn process.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
If that doesnt work, look into this link http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 07, 2011 | 2004 Pontiac Sunfire
Programing a key fob
If this doesnt work, you may have a failure in your system. If the security light is on, and the reprogram doesnt work, you might want to look into bypassing that antitheft system.
Aug 06, 2011 | Oldsmobile Alero Cars & Trucks
How to reprogram key
If this doesnt work, and you are having STARTING issues, go to this link.
Jul 29, 2011 | 2005 Pontiac Grand Prix
Car cranks fine, was running great, cold morning wont start, sprayed start fluid motor runs until either gone. fuel filter?
this could be a few things fuel pump getting weak or your alarm could of activated itself and it disables the fuel to the engine, I would try reseting the built in alarm system. first put the key in the ignition and turn on till all the lights come on and let it sit 10 minutes with the key on, then after the 10 minutes is over turn the key to the off position and wait 3 seconds and then try to start. if it starts which is possible because grand ams and olds aleros are bad for the security system locking up by them self. Hope this helps.
Jan 02, 2011 | 2000 Pontiac Grand Am GT
Vehicle: 2000 Dodge Ram 1500, 5.9L, Automatic Transmission, 171,000 miles. Vehicle will stop running, just shut off, after about 10 minutes of driving. Then after 5 minutes of waiting it will start again...
the first suspect is the igniton switch. when this happens, take the ign key and just barlely turn it, either way, not enough to go off/on just a little tweak, it the lights come back on or flicker, that ign switch will need replacement.
Sep 18, 2009 | 2000 Dodge Ram 1500 Truck
I have a 2000 s500 engine just shut off by itself
you need to have car scanned for codes and it sounds like it is due for a major service
Aug 30, 2009 | 2000 Mercedes-Benz S-Class
Garden Logo
73 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
