Question about Intec PlayStation 3 Turbo Shock III Wireless Controller
My turbo 3 wont connect to my PS3 - Intec PlayStation 3 Turbo Shock III Wireless Controller
Can't connect orb controller to ps3
Plug the dongle in to the USB port, turn on the PS3 and the LED will flash a lot (as if you've pressed the connect button), then press L3 and SELECT together for 3 seconds; it'll then connect. Then press the PS button.
As long as you keep the dongle plugged in, the controller will not disconnect and won't need pairing again.
Jul 27, 2011 | Intec PlayStation 3 Turbo Shock III...
It will not connect to my new ps3. Worked great on my other ps3
To make a controller work with a new PS3, you need to plug it in with a USB cable before it can be used wirelessly.
Feb 28, 2011 | Intec PlayStation 3 Turbo Shock III...
My INTEC Turbo Shock 3 Controller is not working i asked my friend i followed to instructions it did not help please help as soon as possible Thanks Peter
I have the same problem. I disconnected the key, plugged the controller with its original cable. Turned the PS3 on, turning controller on, pressing Sync, connecting the key in PS3. At that state, the 4 leds start to flash slower as it detects the key. Problem is I can never connect to console. I mean I press Home and it never connects. Its been working fine before I updated PS3 to 3.5 version.
Dec 27, 2010 | Intec PlayStation 3 Turbo Shock III...
Im trying to connect my ps3 through my laptop with a telstra turbo usb dongle modem, i cant figure it out
better u download the repair guide to solve your problem easily.. click here to download the repair guide of ps3..
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
My Intec PS3 Turbo Shock Wireless Controller wont sync to my ps3. it is useless. i dont know what else to do. i have never dropped it. it was working fine one day and the next day it did not sync to my...
I've gotten mine to sync fine just follow the steps but press and hold the sync button for like 5-10 seconds. To be honest the best thing you should do is to refund it because mines already broke, cat knocked it over and now I have no vibration..... I've had it for less than a day, both analogue stick move by themselves in game which to me seems like the f*cking thing is demonic and sucks hardcore playing online.Also the sticks arent sensitive they'll jump over things when you move them and add the automoving analogue sticks that your constantly fighting with just makes things like hell Save your money for a higher grade model!!!!
Oct 23, 2010 | Intec PlayStation 3 Turbo Shock III...
My Intec controller will not connect to my ps3 don't no what to do.
Remove the USB receiver from the ps3 console usb port. Turn OFF the ps3 console and the controller. Turn on the ps3. trun the controller to on. press the sync button on the controller. Insert the usb receiver to the usb port. Press Home button. Now I had two controllers one I had to return because no matter what i did it did not link but the 2nd one did this way
Dec 29, 2009 | Intec PlayStation 3 Turbo Shock III...
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont go on the internet
Check and make sure its set to automatically obtain dhcp settings.
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
Won't work
Putting batteries in controller
Turn on the PS3
Turn on controller
Press the sync button, the LEDs will flash rapidly
Insert the usb that comes with the controller, the LEDs flash slowly
Press the home button on the remote
READY.
Jul 25, 2009 | Intec PlayStation 3 Turbo Shock III...
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Intec PlayStation 3 Turbo Shock III Wireless Controller Logo
21 people viewed this question
Top Intec Video Game Consoles & Games Experts
Martin Murray
David
David
Colin Stickland
Colin Stickland
Are you an Intec Video Game Console and Game Expert? Answer questions, earn points and help others
