Question about Keurig B50 Coffee Maker
Coffee machine vibrates very loudly makes quite a lot of noise when taking in the water before it brews.
  • 4 more comments
  • Anonymous Oct 17, 2008
    Coffee
  • justcool Oct 17, 2008
    coffee machine vibrates very loudly.
  • Adam Costa Mar 25, 2009
    Same thing, it says ready, I press small cup brew to try to flush the system since it has not been used in a long time, and the machine gets very loud and vibrates, it's actually kind of scary so I turn it off. Should I leave it on and see what happens? but is sounds like something is going to blow up!, lol. Help Me!
    Sorry,m one other thing to add is after the vibrating starts the screen then displays "not ready" does it usually say that when brewing, or begining to brew?
  • Anonymous Mar 20, 2014
    strted making lots of unusual noise in brew cycle where it's usually kinda quiet; took forever to push water through. Never done this before -- did it again after running vinegar through.
IT VIBRATES WHEN TAKING IN WATER
Posted on Aug 13, 2008
Older style K-Cup machines have a lousy pump. Thats why it's so loud. Newer machines have a newer style pump and are much quieter.
Posted on Jan 21, 2009
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
When brewing it makes a loud noise
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Oct 14, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
Keurig loud squeaking noise
End of life procedure "Say Good Bye" or have a fire!
Mar 03, 2013 | Keurig B60 Coffee Maker
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
Makes loud vibration noise (not there when
brewer needs to be descaled use and care guide recomend it to be done every 3 months. Do it religiously according to that time frame regardless of how filtered your water is
Mar 16, 2010 | Keurig B60 Coffee Maker
Why does the coffee maker make a loud noise right before it brews the coffee?
Usually this is the expansion of steam as the heating element quickly rises to the preset temperature. This process heats the water to the correct temperature and causes the water to flow upward from the water reservoir. Then out the brewing spout over the coffee grounds.
It will usually make strange noises at the end of this cycle too.
The water is used up and remaining steam is vented.
Sounds more like a burping and last minute gurgle really. :)
Hope this helps!
Nov 17, 2009 | Keurig B100 Coffee Maker
The water pump does not appear to be working
The Keurig machine is either clogged with coffee grounds or the air bladder needs to be replaced. Use the key tool under the tray to clean out machine. If this does not work you can have the machine repaird. I hope this works.
Apr 25, 2009 | Keurig B50 Coffee Maker
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Keurig B50 Coffee Maker Logo
2,374 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
