Question about Samsung Refrigerators
Re: Samsung Fridge/Freezer - Model SRL 3928B Control panel buttons do not always operate as they should with regard to on/off and temperature control. If fridge compartment temp. can be set, the set temp. is often not stable and can result in lower fridge compartment near freezing. Also the alarm beeper can sound with no real readout indication of the problem. Q. Is this purely a case of replacing the full control panel or might it be a sign of a simple internal sensor fault? (Otherwise the appliance is in good condition in respect of linings/insulation/ compressor function/etc)
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have an fisher and
Hi and welcome to FixYa, I am Kelly
You should enter the diagnostic mode to determin your fault:
Diagnostic Mode
To enter diagnostic modes, press and hold the MENU button
- then press the UP button for 4 seconds. The PC temperature
will be displayed on the LCD. The actual temperature of the PC is
shown. Note Temperatures are shown in Degrees Centigrade.
PC Sensor Temperature ____
- By pressing the Up button once more, this
will indicate the FC sensor temperature. Note: The "min" indicates minus 12°C
FC Sensor Temperature
- By pressing the Up button once more, this will indicate the Defrost sensor temperature.
Defrost Sensor Temperature
- By pressing the Up button once more, this will indicate the input/Output Status.
Input/Output Status
- Press UP one and two more time, both LCDs display 87.5 but should be ignored
Spare/ Blanks
- Press UP one more time and fault history will be shown.
Fault History
To exit diagnostic mode press MENU button
FAULT CODES:
A wrench symbol and LCD fault code will appear automatically if there is a fault in the
temperature measuring system, defrost system, fans or low ambient heater.
When the PC door is opened an alarm will sound, the number of beeps also indicates
the fault code. Pressing any of the control buttons can deactivate these alarms
Fault Code 1
Reason: On last power up, the power module failed self test.
Primary Action: Replace power module
Fault Code 2
Reason: The previous 2 defrosts were aborted after 30 minutes
Primary Action: Check defrost element
Fault Code 3
Reason: The resistance of all the temperature sensors is outside the normal range
(>45K Ohms)
Primary Action: Check 6 -way Rast connector at power module
Fault Code 4
Fault Code 5
Reason: The resistance of the FC sensors is outside the normal range (>45K Ohms)
Primary Action: Check sensor connector at power module
Fault Code 6
Fault Code 7
Reason: The resistance of the Defrost sensor is outside the normal range (>45K Ohms)
Fault Code 8
Fault Code 9
Reason: The resistance of the PC sensors is outside the normal range (>45K Ohms)
Fault Code 10
Fault Code 11
Reason: The current for the LAH, PC &FC Fan is lower than expected
Primary Action: Check the 6 way fan/LAH, connector at module.
Fault Code 12
Reason: The current for the LAH, PC &FC Fan is higher than expected
Fault Code 13
Reason: LAH is drawing less current than expected.
Primary Action: LAH open circuit
Fault Code 14
Reason: LAH is drawing higher current than expected.
Primary Action: Check wiring connection
Fault Code 15
Reason: PC fan is drawing less current than expected.
Primary Action: PC fan open circuit
Fault Code 16
Reason: PC fan is drawing higher than expected current
Primary Action: Check fan wiring or connections
Fault Code 17
Reason: FC fan is drawing less current than expected.
Primary Action: FC fan open circuit
Fault Code 18
Reason: FC fan is drawing higher current than expected.
Primary Action: Check FC fan & wiring circuit
There are also Ice maker faults that are NOT included above. This should get you started and if everything passes above diagnosis the problem is most likely in your ice maker circuit. The reason I did not include ice maker faults is because they do not cause alarms.
Thanks for choosing FixYa,
Kelly
Posted on Mar 15, 2011
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
I dont now how to set temperature for samsung rsh1nhmh . All the light in the house vent off and the plugs . Now on the frige screen is only a flashing light. Nothing else
The refrigerator temperature can be set between 7?C (46°F) and 1?C (34°F) to suit your particular needs. Press the Fridge button repeatedly until the desired temperature is shown in the temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the Fridge button to set your desired temperature. After a few seconds, the Fridge will begin tracking towards the newly set temperature. This will be reflected in the digital display.
http://safemanuals.com/314159.php?k=2f8f21dfdc6e62cb4825d07d38bad88d&ID=471000&q=SAMSUNG%20RSH1NHMH
Nov 18, 2010 | Samsung Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Refrigerators Logo
56 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
